GM ECM Connectors
1 Post
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
GM ECM Connectors
Does anyone have the part numbers for GM ECM connectors? Specifically for ECM 1227730.
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
1 Post
Engine: 355 SD TPI
Re: GM ECM Connectors
that website doesnt have the GM part numbers listed, but thanks anyways.
Engine: LB9
Axle/Gears: 3.55
leave mike a message at mike@eficonnection.com and he will know what you need.
He has built me several harnesses in the tpi and obdii version.
Top quality.
Ron
Top quality.
Ron
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Some info on connectors here.
https://www.thirdgen.org/forums/diy-...27727-ecm.html
