Stock PROM for 1987 GTA, 350 TPI
Hello
I am searching a stock PROM for an 1987 Pontiac Trans Am GTA, 350 TPI automatic. Where can I find this? I heard that GM don't produce new ones...
Fit the 88 GTA PROM also for the 87? Or are they different?
Thank you for an answer.
Simon
Simon
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: Stock PROM for 1987 GTA, 350 TPI
Yeah, you can use an 88 prom, same ECU. 88 prom may actually have upgrade so you might be better off. What makes you think your prom is bad?
Car: check
Engine: check
Transmission: check
The reference voltage is hardware based. You can remove the PROM (MEMCAL) and it won't change.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
I saw your post on the tech board about this issue. If you checked the reference voltage at the CTS with the CTS plugged in, it will be lower then the +5 volts you expect.
You can also check the reference voltage at the TPS connector. Key-on, engine-off, if an inline connector measure between the two outer pins. It should be in the 5.0 - 5.1 volt range. Can do this with it unplugged from the sensor.
As for the malfunction code, it is common for the CTS sensor and connector to need replacing at the same time. They always seem to corrode, both the sensor pins and the connector terminals.
RBob.
RBob.
Ok, I will check this.
But how can I measure the CTS, when the connector is plugged in? I only check the voltage at the connector and it's 4.1 volts...
Car: check
Engine: check
Transmission: check
RBob.
Also, are the 4.1 volts on the cts connector ok? Sorry but I'm confused.
First, on the TPS there should be ca. 5 Volts beetween the two cables on the side?
But on the CTS, is not the 5 Volt reference neccassary?
Thank you for your response.
Car: check
Engine: check
Transmission: check
First, on the TPS there should be ca. 5 Volts between the two cables on the side?
RBob.
Today I tested the TPS. 5 Volts and it's ok. I disconnect also the MAT and the voltage at the CTS connector was still 4.1 volts.
my mechanic don't know where the problem is... grounds are ok, fuses are ok, and ecm is ok.
Update:
Another mechanics tested yesterday the reference voltage. All connectors have 5 Volts!
We also adjusted the TPS at 0.54 Volts at idle and replaced the CTS connector.
I will see if my problem whit the fans is gone...
Thank your for your help!
Fred SS
10-12-2015 11:27 AM
TX-SleeperC5
09-24-2015 03:13 PM
