84 Camaro RS Speedo problem
Car: 1984 Camaro Sport Coupe
Engine: 2.8L V6
84 Camaro HELP US IDENTIFY THIS CAR!
Hey guy's the speedometer gauge in my dash doesn't work, when I accelerate it just moves somewhat.
I think it's the sensor but I dont know where that is?
Could someone tell me?
tylor360
tylor360
Car: 1986 red trans am
Engine: 305- JE pistions, edlebrokc intake,
Axle/Gears: 373s
look on the tranny
the cable is probably justy loose in the tranny, check the cable comming down on the driver side of the tranny
Engine: 2.8L V6
Also, I have gauges in the dash for battery and 2 other things I think that don't work at all for some reason. Any ideas on why nothing would be showing up. They just light up to show how full/ low they are, they dont have a pin rotating.
I dont really know how to explain it but I hope you understand me?
Engine: 2.8L V6
I'm sorry it's just I don't know much about cars, I'm only 16 Computers are my thing lol
Which part is the tranny under there? I only know the basics and I dont know which wire would be the speedometer one.
tylor360
tylor360
Engine: 2.8L V6
Ok so I put the car up and cleaned off all around the sensor and then took it out...its a 4 circle type thing with only prongs in 3 of the holes. I don't think it's loose because it was in their pretty snug so I took it out and wiped it off and everything and then put it back in and it's still not fixed, the speedometer just wiggles when you drive instead of showing an accurate readout.
Please help
Tylor360
Please help
Tylor360
Car: Now Camaorless
Your speedometer cable could be broken, if so one end of it will be turning as you drive but the other end will not. It would be just rubbing the two broken ends together and causing your needle to jiggle. 84 should be cable driven not sensor driven.
Engine: 2.8L V6
Thats what my dad said too, but it has three prongs in a four part plastic piece, and that's the only thing I see on the side of the drivers side of the tranny.
Could it be somehwere else or could it accually be sensor driven.
The temp, oil, and battery gauges are accually digital too, not like a number or anything but it's not the kind with a pin, it just has a few lights that light up around in that curve around the circle to tell u how how/low it is.
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
From reading your description above, not too certain that you found the speedo cable assembly. True, it's located on the drivers side but, near the tailshaft housing. A cable driven speedo will have a flexible steel outer coating and will be attached to the transmission with a round female coupler. Find that then simply use a pair of channel locks to unfasten it from the transmission. Check the end of the drive cable for signs of wear. You may need to also remove the speedo gear housing from the transmission to inspect the female end of the plastic driven gear. But first check your cable for breakage. Replacing the speedo cable isnt that hard but it'll consume some time.
Car: Now Camaorless
So you're saying that your entire gauge cluster is a factory digital including the speedometer?
Engine: 2.8L V6
I am positive it is the original gauge in there but I'm gunna get under the car again today and look around see if there are anymore wires.
Tylor360
Engine: 2.8L V6
Well I found the speedo cable and it is cable driven, I attached a drill to it to spin it at a constant rate and it will go to that rate but still wobble, Do you guy think this is my gauges are bad or what?
Tylor360
Tylor360
Car: 1985 Trans-Am
Engine: 305 LG4 4bbl
Axle/Gears: 3.27 Limited Slip
Seems you have a Berlinetta. There was no such thing as an '84 Camaro RS :P
All 82-84 Camaros were cable speedo driven. Make sure there is lubracation oil in the cable itself. IF there isnt any, or its low it would affect how it works. I know my speedo in my 83 wobbles a bit. It's mechanical though, so its expected to a degree
-OSS
-OSS
Engine: 2.8L V6
-OSS
-OSS
Did the Berlinetta come in a V6? And it's not the entire dash that's digital, its just the oil temp (pressure) battery and engine temp just have lights that light up instead of a usual pin on a guage. The right big gauge is speed and the left big one is how much gas is in it.
Help me out guys, this car surprizes me every day with something new!
I'll get some pictures of the dash better but if you's would like to see the car for more input here is a link to another forum that I posted alot of pictures on Page 5.
Overclock.net - Overclocking.net
It's a gunmetal metallic and I painted the rims that came with it a flat black because they were rusty and everything and I thought the flat black would match the louvers
Car: 1985 Trans-Am
Yes, the Berlinetta came in V6 as well as V8. The berlinetta was the luxerious version of the Camaro, sporting the famous all digital instrument cluster for 1985 I believe. Tell me this- when you open the door, does the car play a little song for you?
Check this link out, it should tell you just about anything you need to know. Also, we can futhur assist you if you provide the RPO codes for us.
The RPO codes are "Regular Production Options", and they are printed on a sticker usually in your middle console. They are 3 letter groups, and each grouping designates a particular thing. For example..If you have a rear window defogger, you might see "DP0", have a 5 speed tranny? "T2I" or something, I just made those up, but you get my idea. There are about 35 of these numbers written down, so copy them all down, and post back here, and I'll decode them all for you, it will tell you exactly what your car is.
-OSS
-OSS
Engine: 2.8L V6
-OSS
-OSS
And did you look at those pictures on that site of the link I put in my previous post?
Thats my camaro, it has pictures of the inside and stuff, The hood with louvers isnt original so don't judge what the car is by that
Tylor360
Engine: 2.8L V6
There is a longer thing above all of these 3 digit codes
It's
1G1AP8719EN139611
AR9 AU3 A01 A31 A90 BS1 BX5 B18 B9K C60 D02 D1T D35 D80 E52 E6N E92 FB8 FB9 GA3 GA4 GU5 J50 K19 K64 LC1 MD8 MX0 NA5 NB1 N0D N33 QMX U29 VK3 V73 YR1 YT1 YT9 Y06 1AY 19L 19U 6DA 60C 60I 609 7DA 8PK 9PK
The 0's and o's can be changed, I couldnt make out whether it was an o or a zero
What is that longer thing that comes at the start of it?
It's
1G1AP8719EN139611
Car: 1985 Trans-Am
OK- I decoded all your RPO's for you. Here is what came up-
A01
WINDOW, TINTED, ALL SHADED, W/S
A31
WINDOW, POWER OPERATED, ALL DOORS
A90
LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
AR9
SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3
LOCK CONTROL, SIDE DR, ELEC
B18
ORNAMENTATION, INTR, DELUX
B9K
ORNAMENTATION, B/S MLDG, REAPPLY TO RR DOORS ONLY
BS1
INSULATION, ACOUSTICAL PKG
BX5
ORNAMENTATION, EXTR MLDG, ROOF DRIP, PAINTED
C60
HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
D02
PAINT, ENAMEL MASTER
D1T
GEAR, SPEEDO DRIVEN
D35
MIRROR, OUTSIDE REAR VIEW
D80
SPOILER, RR END PNL
E52
DOOR RR, 83 INCH, WRAP AROUND
GU5
AXLE REAR, 3.23 RATIO
J50
BRAKE SYSTEM, POWER
K19
REACTOR SYSTEM, AIR INJECTION
K64
GENERATOR, 78 AMP
LC1
ENGINE, GAS, 6 CYL, 2.8L, 2B8L, V6, LONGITUDINAL
MD8
TRANSMISSION, AUTO 4 SPD, THM 700 R4
MX0
MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5
EMISSION SYSTEM, FEDERAL, TIER O
NB1
EMISSION SYSTEM, CLOSED LOOP
A01
WINDOW TINTED ALL, SHADED WINDSHIELD
A31
WINDOW POWER OPERATED, ALL DOORS
A90
LOCK CONTROL RR CMPT LID, REM CONT ELEC RELEASE
AR9
SEAT FRT BKT, DELUXE
AU3
LOCK CONTROL SIDE DR, ELEC
B18
ORNAMENTATION INTR, DELUXE
B9K
ORNAMENTATION B/S MLDG REAPPLY TO RR DOORS ONLY
BS1
INSULATION ACOUSTICAL PKG
BX5
ORNAMENTATION EXTR, MLDG, ROOF DRIP, PAINTED
C60
HVAC SYSTEM AIR CONDITIONER FRT, MAN CONTROLS
D02
PAINT SOLID
D35
MIRROR O/S LH, REMOTE CONTROL, RH MANUAL CONTROL, COLOR
D80
SPOILER RR END PNL
E52
BODY EQUIPMENT ONE PIECE LIFT GATE WITH LIFT GLASS
E6N
COUNTRY ABU DHABI
E92
DOOR DYNAMIC SIDE IMPACT - DELETE
FB8
FLEET INCENTIVE WESTERN EXTERMINATING (H/N/W-TRK CKST)
FB9
FLEET INCENTIVE CAPITAL ELECTRIC (W-TRK CKGST)
GA3
FLEET INCENTIVE ALYESKA PIPELINE COMPANY (TRK CKGMLST)
GA4
FLEET INCENTIVE PERFORMANCE CONTRACTING GROUP (H/K/U/W-TRK CKGST)
GU5
AXLE REAR 3.23 RATIO
J50
BRAKE SYSTEM PWR
K19
REACTOR SYSTEM AIR INJECTION
K64
GENERATOR 115 AMP
LC1
ENGINE DIESEL, 4 CYL, 4.4L, DI, L4, TURBO, OHC, ISUZU
MX0
MERCHANDISED TRANS AUTO PROVISIONS, O/D
NA5
EMISSION SYSTEM FEDERAL, TIER 0
NB1
EMISSION SYSTEM CLOSED LOOP
A01
A31
A90
AR9
AU3
B18
B9K
BS1
BX5
C60
D02
PAINT SOLID
D35
D80
SPOILER RR END PNL
E52
E6N
COUNTRY ABU DHABI
E92
FB8
FB9
GA3
GA4
GU5
J50
BRAKE SYSTEM PWR
K19
K64
GENERATOR 115 AMP
LC1
MX0
NA5
NB1
A01
A31
A90
AR9
AU3
B18
B9K
BS1
BX5
C60
D02
PAINT SOLID
D35
D80
SPOILER RR END PNL
E52
E6N
COUNTRY ABU DHABI
E92
FB8
FB9
GA3
GA4
GU5
J50
BRAKE SYSTEM PWR
K19
K64
GENERATOR 115 AMP
LC1
MX0
NA5
NB1
A01
A31
A90
AR9
AU3
B18
B9K
BS1
BX5
C60
D02
PAINT SOLID
D35
D80
SPOILER RR END PNL
E52
E6N
COUNTRY ABU DHABI
E92
FB8
FB9
GA3
GA4
GU5
J50
BRAKE SYSTEM PWR
K19
K64
GENERATOR 115 AMP
LC1
MX0
NA5
NB1
A01
A31
A90
AR9
AU3
B18
B9K
BS1
BX5
C60
D02
PAINT SOLID
D35
D80
SPOILER RR END PNL
E52
E6N
COUNTRY ABU DHABI
E92
FB8
FB9
GA3
GA4
GU5
J50
BRAKE SYSTEM PWR
K19
K64
GENERATOR 115 AMP
LC1
MX0
NA5
NB1
A31
A90
AR9
AU3
B18
B9K
BS1
BX5
C60
D02
D1T
GEAR, SPEEDO DRIVEN
D35
D80
SPOILER, RR END PNL
E52
GU5
J50
BRAKE SYSTEM, POWER
K19
K64
GENERATOR, 78 AMP
LC1
MD8
MX0
NA5
NB1
A01
A31
A90
AR9
AU3
B18
B9K
BS1
BX5
C60
D02
PAINT SOLID
D35
D80
SPOILER RR END PNL
E52
E6N
COUNTRY ABU DHABI
E92
FB8
FB9
GA3
GA4
GU5
J50
BRAKE SYSTEM PWR
K19
K64
GENERATOR 115 AMP
LC1
MX0
NA5
NB1
A01
A31
A90
AR9
AU3
B18
B9K
BS1
BX5
C60
D02
PAINT SOLID
D35
D80
SPOILER RR END PNL
E52
E6N
COUNTRY ABU DHABI
E92
FB8
FB9
GA3
GA4
GU5
J50
BRAKE SYSTEM PWR
K19
K64
GENERATOR 115 AMP
LC1
MX0
NA5
NB1
A01
A31
A90
AR9
AU3
B18
B9K
BS1
BX5
C60
D02
PAINT SOLID
D35
D80
SPOILER RR END PNL
E52
E6N
COUNTRY ABU DHABI
E92
FB8
FB9
GA3
GA4
GU5
J50
BRAKE SYSTEM PWR
K19
K64
GENERATOR 115 AMP
LC1
MX0
NA5
NB1
A01
A31
A90
AR9
AU3
B18
B9K
BS1
BX5
C60
D02
PAINT SOLID
D35
D80
SPOILER RR END PNL
E52
E6N
COUNTRY ABU DHABI
E92
FB8
FB9
GA3
GA4
GU5
J50
BRAKE SYSTEM PWR
K19
K64
GENERATOR 115 AMP
LC1
MX0
NA5
NB1
A01
A31
A90
AR9
AU3
B18
B9K
BS1
BX5
C60
D02
PAINT SOLID
D35
D80
SPOILER RR END PNL
E52
E6N
COUNTRY ABU DHABI
E92
FB8
FB9
GA3
GA4
GU5
J50
BRAKE SYSTEM PWR
K19
K64
GENERATOR 115 AMP
LC1
MX0
NA5
NB1
19L
SECONDARY COLOR, EXTERIOR, LAMP BLACK (91)
19U
PRIMARY COLOR, EXTERIOR, LAMP BLACK (91)
1AY
STOCK ORDERS PROCESSING OPTION (DEALER ORDERED CAR)
19U
1AY
Car: 1985 Trans-Am
609
SEAT BELT COLOR, MED COGNAC (91)
60C
TRIM COMBINATION, CLOTH, MED COGNAC (C) (91)
60I
INTERIOR TRIM, MED COGNAC (91)
N33
STEERING COLUMN, TILT TYPE
QMX
TIRE ALL, P195/75R14/N WS2 R/PE ST TL ALS
U29
LAMP, INTR I/P, COURTESY
V73
ANTENNA, FIXED
V73
VEHICLE STATEMENT, USA/CANADA
VK3
LICENSE PLATE, FRT MOUNTING PKG
Y06
RING GEAR, 9.50 IN., SAGINAW, (S.P 0.)
YR1
SEAT,FRT CUSTOM
YT1
BUILD UP DR & QTR
YT9
OPTION PACKAGE, FISHER FURNISHED PARTS
19L
SECONDARY COLOR EXTERIOR, LAMP BLACK (96)
19L
SECONDARY COLOR EXTERIOR, SHERWOOD GREEN MET (96)
19L
SECONDARY COLOR EXTERIOR, ALPINE GREEN MET (97)
19L
SECONDARY COLOR EXTERIOR, DK BLUE PEARL MET (99)
19L
SECONDARY COLOR EXTERIOR, ABYSEE GREEN PEARLESCENT (BRAZIL)
19U
PRIMARY COLOR EXTERIOR, JET BLACK (05)
19U
PRIMARY COLOR EXTERIOR, DK BLUE PEARL MET (02)
19U
PRIMARY COLOR EXTERIOR, DARSENA BLUE PEARLESCENT (02) BRAZIL
19U
PRIMARY COLOR EXTERIOR, EBONY BLACK (02) HOLDEN
19U
PRIMARY COLOR EXTERIOR, LUXO BLUE TINTCOAT (04)
19U
PRIMARY COLOR EXTERIOR, BLACK MICA MET (04)
19U
PRIMARY COLOR EXTERIOR, LAMP BLACK (02)
1AY
ORDER MODIFICATION STOCK
19L
19L
19L
19L
19L
19U
19U
19U
19U
19U
19U
19U
1AY
19L
19L
19L
19L
19L
19U
19U
19U
19U
19U
19U
19U
1AY
60C
TRIM COMBINATION CLOTH, MED COGNAC (C) (91)
60I
INTERIOR TRIM MED COGNAC (91)
60I
INTERIOR TRIM NEUTRAL SHALE (97) OPEL
60I
INTERIOR TRIM CAPPUCCINO (01) OPEL
60I
INTERIOR TRIM LIGHT NEUTRAL (00) (HOLDEN)
6DA
COMPONENT FRT LH COMPUTER SEL SUSP (6DA)
7DA
COMPONENT FRT RH COMPUTER SEL SUSP (7DA)
8PK
COMPONENT RR LH COMPUTER SEL SUSP (8PK)
9PK
COMPONENT RR RH COMPUTER SEL SUSP (9PK)
N33
STEERING COLUMN TILT TYPE
QMX
TIRE ALL MIXED SIZES (FRONT & REAR)
U29
LAMP INTR, I/P COURTESY
V73
VEHICLE STATEMENT USA/CANADA
VK3
LICENSE PLATE FRONT FRT MOUNTING PKG
Y06
RING GEAR 9.50 IN, SAGINAW, (S.P.O.)
YT1
FLEET PROGRAM FALL/WINTER/SPRING REPURCHASE (B/C/D/F/G/H/J/K/M/NS/U/V/W/Z-TRK CKGJMPST
YT9
FLEET PROGRAM EXPOSURE INITIATIVE I: C/F/G/H/J/K/M/N/S/U/V/W/Z- TRK CKGMPST
19L
19L
19L
19L
19L
19U
19U
19U
19U
19U
19U
19U
1AY
60C
60I
60I
60I
60I
6DA
7DA
8PK
9PK
N33
QMX
U29
V73
VK3
Y06
YT1
YT9
19L
19L
19L
19L
19L
19U
19U
19U
19U
19U
19U
19U
1AY
60C
60I
60I
60I
60I
6DA
7DA
8PK
9PK
N33
QMX
U29
V73
VK3
Y06
YT1
YT9
19L
19L
19L
19L
19L
19U
19U
19U
----------SEAT BELT COLOR, MED COGNAC (91)
60C
60I
N33
QMX
U29
V73
ANTENNA, FIXED
V73
VK3
Y06
YR1
SEAT,FRT CUSTOM
YT1
BUILD UP DR & QTR
YT9
19L
19L
19L
19L
19L
19U
19U
19U
19U
19U
19U
19U
1AY
19L
19L
19L
19L
19L
19U
19U
19U
19U
19U
19U
19U
1AY
19L
19L
19L
19L
19L
19U
19U
19U
19U
19U
19U
19U
1AY
60C
60I
60I
60I
60I
6DA
7DA
8PK
9PK
N33
QMX
U29
V73
VK3
Y06
YT1
YT9
19L
19L
19L
19L
19L
19U
19U
19U
19U
19U
19U
19U
1AY
60C
60I
60I
60I
60I
6DA
7DA
8PK
9PK
N33
QMX
U29
V73
VK3
Y06
YT1
YT9
19L
19L
19L
19L
19L
19U
19U
19U
19U
19U
19U
19U
1AY
60C
60I
60I
60I
60I
6DA
7DA
8PK
9PK
N33
QMX
U29
V73
VK3
Y06
YT1
YT9
19L
19L
19L
19L
19L
19U
19U
19U
19U
19U
19U
19U
1AY
60C
60I
60I
60I
60I
6DA
7DA
8PK
9PK
N33
QMX
U29
V73
VK3
Y06
YT1
YT9
19L
19L
19L
19L
19L
19U
19U
19U
19U
19U
19U
19U
1AY
60C
60I
60I
60I
60I
6DA
7DA
8PK
9PK
N33
QMX
U29
V73
VK3
Y06
YT1
YT9
19U
19U
19U
1AY
60C
60I
60I
60I
60I
6DA
7DA
8PK
9PK
N33
QMX
U29
V73
VK3
Y06
YT1
YT9
19L
19L
19L
19L
19L
19U
19U
19U
19U
19U
19U
19U
1AY
60C
60I
60I
60I
60I
6DA
7DA
8PK
9PK
N33
QMX
U29
V73
VK3
Y06
YT1
YT9
Also, here is the link I was trying to add doesnt seem to want to code properly, so go to camarosource.CA and select 1984 on the left side, then select the Berlinetta, and you're set! *EDIT* OK, apparently I pasted the first part three times in 1 post lol...
-OSS
Engine: 2.8L V6
Ok well I went on that site and it says that 84 Berlinetta's only came in 5 speed manual. Mine is a (4 speed?) automatic
Did you look on that site I posted before of pictures of my car? I can't find another camaro with gauges like that?
I remember reading that the wood accents and stuff were an option on the car. But I think i was searching for a 84 Camaro RS?
I'm so confused with this carrrr lol
Help me out, are you sure it's a berlinetta?
Did every Berlinetta come with the all digital gauge cluster? Because mine doesn't have that.
Update
Just read that the berlinetta came with a 4 speed auto, so I was wrong with that, but I don't have the all digital gauge cluster
Update
Engine: 2.8L V6
I have been reading on that site and I'm convinced it's a 1984 Camaro Sport Coupe, a slight better version of the base coupe, but it has a 4 speed automatic with overdrive and 107 HP.
It seems like whoever bought this car got all the pretty options such as bucket seats and wood accents on the dash, and an upgrade sound system.
I'm glad I finally figured this out.
Car: 1985 Trans-Am
I'm glad too, To answer one question. THe number you posted was the VIN number, vehical identification number, I;ll decode that for you too.
OK, so the VIN 1G1AP8719EN139611 represents the following
1- USA
G- General Motors
1-chevrolet
A- Non passive restrant
P- Base or Z28 (This would confirm your sport coupe idea)
87- 2 Door Coupe
1- LC1 153ci V6
9- Check digit..digit is good (this number is just to confirm the VIN is real)
E- 1984
N- Norwood, Ohio
139611- number on production line
1- USA
G- General Motors
1-chevrolet
87- 2 Door Coupe
1- LC1 153ci V6
E- 1984
N- Norwood, Ohio
Engine: 2.8L V6
1- USA
G- General Motors
1-chevrolet
87- 2 Door Coupe
1- LC1 153ci V6
E- 1984
N- Norwood, Ohio
1- USA
G- General Motors
1-chevrolet
87- 2 Door Coupe
1- LC1 153ci V6
E- 1984
N- Norwood, Ohio
Engine: 2.8L V6
Do I need the exact gauge cluster for the car? Like with the gas on the left and the speed on the right. Could I get a gauge cluster with RPM's on the left and hook it up to the car, or isnt that possible if it didnt come with it?
THanks
tylor360
THanks
tylor360
Car: 1985 Trans-Am
You can install a guage cluster from another camaro, yes. It would require wiring, but you can do it. I'm not a guy to ask about wiring though :P But as I mentioned, you can install a different guage cluster at the cost of wireing it all up.
-OSS
-OSS
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Do not confuse idot lights for digital gages. Big difference. Only 87 and 88 GTAs had digital clusters. There is such thing as V6 coupes without Berlinetta package. They're called Camaros.
he is not saying that his cluster is digital. there were some camaros that came with for lack of a better term "semi-digital" gauge clusters. they come with 3 gauges: oil pressure, temp, and volts that are a circle with lights at go from teh 6 oclock position counter clockwise to the 12 oclock position., these light up red to show the levels and are needleless.
tyler360 your cable is most likely broken and there is no need to replace the spedometer there is almost no way that it just stops functioning. i sugest you replace the cable.
also your link to the pictures dont work.
and finally i know this is an old thread but i felt like posting.
Car: 1984 firebird
Engine: 2.8 v6
Axle/Gears: soon: A working car.
Re: 84 Camaro RS Speedo problem
Hey, off topic. isn't there a full VIN in here, I was going along the forum and read that they aren't good to post. something about being stolen and bad stuff.
Just giving a heads up.
would an 84 camaro be all the desireable to steal the vin off of?
ah, either way you can see the vin number at clean as day when you walk up to a car, Just go to any walmart, you can get at least 50 of them
no doubt, not knocking it. Just sayin. Kinda crazy tho, it is basically the social security number of your car and it can be exploited that easily... its sad. Kinda like that gift card issue, people writing down the numbers on the back of gift cards and then go home and check to see when there is money on them when someone else purchases them... not cool
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
That's why I always cover the VIN on all my cars. I only uncover it for the inspection. On some cars, you can cover it inside, under the windshield, on others you can't and you need to use tape on the oustide of the windshield. Never had anyone pull off my tape, though.
Car: 1984 firebird
Engine: 2.8 v6
crazy, good idea. or let it rust up on such an old car. I am probably going to cover mine up with an FU bunny, on the womans 'zuki and maybe a pontiac logo on the bird.
1 Post
Car: 1984 Chevy Camaro
Engine: 2.8L V6
Transmission: THM 700R4
Your car sounds alot like mine, 84, v6, sport coupe, thm 790r4 automatic tranny, norwood ohio manufacture plant, and wobbly speedometer. Mine doesnt go wonky til I get up to 50mph though. I'm definitely look in to it applying the info I gathered here and ill post if I learn anything pertinent that may help your cause.
Im also more computer literate than car, but with my camaro that is rapidly changing I suggest a haynes repair manual. They are very handy when just starting out.
92camaroJoe
08-13-2015 06:07 AM
beachrodder
08-07-2015 04:27 PM
