Power Door Locks Not Working At All
Old 07-28-2007, 06:59 PM
xGR1Mx's Avatar
Hey everyone. If your reading this, I thank you for at least clicking on the thread. My power door locks do not work at all. They don't work on either side, so I don't know if it's the relay or the fuse. So, a few questions.. One, Where is the relay? Second, what fuse is the one that controls the power door locks? The same one as the radio and the windows, or what? Lemme know of anything you think of, and it will be much appreciated.
Thanks everyone,
Grim
Old 07-29-2007, 12:07 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Power Door Locks Not Working At All
Does the overhead light come on when you open the door? If not, that is the ACC fuse that is blown.
Old 07-29-2007, 12:39 AM
xGR1Mx's Avatar
Yeah, the overhead light comes on along with the lights underneath the dash. They dont turn on when open the passenger door though, but thats most likely a whole different problem. I was looking at the actuators today and they dont make any noise or anything.
Old 07-29-2007, 01:40 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Bust out a multi-meter. Life-saving electrical problem diagnoser (you can add that word to the dictionary if you'd like). Find out if you have voltage to the switch. Find out if the switch gives power to the actuator. Figure out the rest from there. Try both switches first though before you go rippin apart your door. If neither switch operates either actuator, it's most likely not the switch or the actuators. Never do two of the same parts go bad at the exact same time, except when people make statements like this one. drop your dash off (don't disconnect wires, just unbolt all of it so you can pull it off and look at the wires behind it).
Old 07-29-2007, 02:39 PM
xGR1Mx's Avatar
Damn.. This sounds like its gonna be fun.. They never worked since I had the car though. They didn't just die.. Ive had the car for almost a year now too, just one of those things you never get around to, haha. Also, I don't know if this could have anything to do with it, but when it's hot out, and the inside of my car gets decently hot.. my power windows don't go down. But all i do is take a cooler fuse from my console and switch it with the hotter one, and then they work again. So i don't know if there's something with my fusebox or not..
Old 07-29-2007, 10:16 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Power Door lock problems are almost ALWAYS the result of poor contact. Clean the plug connection at the door lock. Clean it VERY WELL ! I can't even count the cars I have worked on where I cleaned them terminals ( on the motor and the plug in many cases ) and got the locks working again.
If your going to go through the trouble of taking off the door panels you might as well pull the lock motors right out of the door so you can clean those terminals too. Just drive the pin from each rivet - then drill each rivet out. ( it takes about 2 minutes) Be sure to buy/get 4 short 10 mm nuts and bolts to re-mount the locks when your finished.
You could also remove the drivers Kick panel and expose the lock relay. The relay is grounded when it's screwed to the body - so make sure there is no rust and good contact where it screws to the body. The connections here are usually good - but unplug and plug them in a few times while the relay is exposed.
Old 07-30-2007, 01:30 PM
xGR1Mx's Avatar
Thanks alot, i'll try everything. Thanks for the help everyone!
Old 07-30-2007, 03:36 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
This is the diagram for door locks for your year model. (on the left half)
http://www.austinthirdgen.org/mkport..._continued.gif
And this is a blown-up diagram that shows the insides of the switches and relay.
http://www.austinthirdgen.org/mkport...door_locks.jpg
Hope this helps.
Lou
Old 02-17-2013, 01:34 AM
asm383's Avatar
Car: 91 z28 convertible
Engine: 350lt1
Do you have a picture of this relay grounded because I can't find anything not too sure which one is the relay
Old 02-17-2013, 05:01 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
If you remove the driver's side kick panel you will see the relay down low in the hole. If I recall correctly, I believe the relay gets it's ground from the sheet metal screw that mounts it to the body.
Old 02-21-2013, 03:43 PM
RockShowTrader's Avatar
Car: 1988 GTA
Their is a ton of crap under that kick panel! Where should the relay be? My diagram says 'Left shroud near lower access hole'. I don't know where that is!
Old 02-21-2013, 05:28 PM
asm383's Avatar
Engine: 350lt1
I took off my kick panel saw a relay but there's no metal in the housing to be grounded
Old 02-23-2013, 07:03 PM
Kathleen Brown's Avatar
Car: 84' Camaro & 71' Camaro
Engine: V6 & 350
I also can't find where it is grounded. I am getting some power to mine but not enough. The volt meter reads only 10 not 12. Am I wrong that it should be 12? Ifmot why would it only get 10?
Old 02-23-2013, 09:10 PM
85FBTranam's Avatar
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
The relay is the rectangular box in the top of the picture. The tab off the relay is the mount point and also the ground. It is affixed to the car with a single screw.
Old 04-13-2013, 03:17 PM
sointenze's Avatar
So to follow up on this, I have my own problems. Have an 84 5.0 Z28 with definetly a bad relay. I ordered a new one from Ricks and the one that showed up only had four pins. When I called they said that was the only relay they were aware of so I sent it back. Does anyone know where I can order a replacement relay for the car, or was that relay some kind of modification made by chevy at some point
Joe
Old 05-05-2013, 02:14 PM
Neal Humby's Avatar
Car: 1986 Camaro Berlinetta
Engine: 305 carb
Transmission: 700R
fixed m ine! Thanks, May 2013
Old 05-06-2013, 08:36 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
This correct? My door locks keep locking and unlocking killing my battery every night, so what may cause this, as I'm about to rip the doors off and clean everything up. But if I could get the parts before I do knowing it's an actual problem instead of poor contact would be appreciated. Thanks.
http://www.autozone.com/autozone/par...er=221870_0_0_
Frozer!!!
01-19-2024 04:55 PM
1992 Trans Am
05-10-2023 07:19 PM
BRoss99
12-07-2020 06:50 PM
Vintageracer
01-10-2020 05:33 PM
colton_carlson
03-08-2019 12:21 PM
Quick Reply: Power Door Locks Not Working At All
