climate control "hissing" sound
Car: 91 Z28
not sure where to post this. my climate control has a hissing or air leak type sound that gets louder the farther you move it to the right. i also don't think i am getting enough air blowing from the lower vents when on the heat setting, or even on vent setting. the blower motor is working and it's noise level increases appropriately as you turn the level ****. is there a vacuum line behind the climate control? any other ideas? car is a 91.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: climate control "hissing" sound
So you have a vac leak somewhere.
Vent positions are changed by vac operated actuators operated by the programmer which is
controlled by the headunit
Vette system shown but F-Body vac lines would be similar
Car: 91 Z28
so does someone know if those actuators are behind the climate control panel or exactly where they are located?
https://www.thirdgen.org/forums/atta...duct010707.jpg
JamesC
Car: 82 Z28
Transmission: T400
Like shown in the sample Vette diagram, the actuators are mounted in various positions on the A/c ducting
under the dash where the vent doors are
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
The actuators (diaphragms) are only visible from the driver side if you stuff your head down by the foot petals. Two are on the end of the HVAC box, and one is behind it. There is another in upper right corner of the firewall that is the fresh air mix. Pictures of the actuators are in this post of my build thread,
https://www.thirdgen.org/forums/ltx-...ml#post5965742
Pull the control head unit. The hissing you hear is a leak where all the vac lines connect to the head unit. There is a plastic keeper that holds the vac lines to the adjustment part. The plastic keeper is in the center of the adjustment part. Replace this part and your hissing with be eliminated
I call it the "heater thingy."
Here's how you fix it for a couple bucks:
I did the repair after ordering the new selector. The repair stopped working so replaced the old one with the new one. Now, it's stopped working. So, going to try this repair on the new one. If that doesn't get it, not sure what to do. Sucks that I finally got the AC working but can't get it to come out the proper vents.
EDIT: took the new one and the old one and made one. this time, used the nut/bolt method above. used the old rubber piece because it looked to be in better condition than the "new" one, which was basically a refurbished one, i think. anyhoo, also, soaked the rubber part in brake fluid for 20 mins, give or take. tightened the bolt/nut fairly snug so that the mechanism worked fairly tight, but still slid. put it all back together and it works like a champ, no hissing and the air moves from defrost to vent to floor quickly.
fix worked. i think the first time i did it i was afraid of tightening the nut/bolt too tight which is why it didn't work. hopefully, this time it'll keep working. if not, i'll pull it, soak it in brake fluid and again and tighten it down some more.
Received 1,672 Likes
Rather than soaking it in brake fluid, which deteriorates the rubber even though it softens it up in the short term, I'd suggest using dielectric grease on it when you put it together.
Car: 1992 firebird
https://youtu.be/Mv782CIJDks
Car: 1992 firebird
those i have.. but on the other side there is another rubber fitting that doesn’t seem to have any kind of clip
I was editing when I noted your response. I don't recognize that piece offhand. It's not on the extra HVAC head that I have lying around, but perhaps it's missing a part.
JamesC
JamesC
1 Post
Car: 91 RS
Engine: 5.3 LS
Axle/Gears: 3:23
Seems like 99% of the problems are with the vent selector. Mine wasn't, mine was the smaller one on the left side that I would say goes to the valve for cars that have the heater hose bypass under the hood on the passenger side valve cover. After doing a simple fix I realized what it actually did. I've LS swapped my car and don't have the bypass anymore so I could do away with that selector. But for those that still have the bypass valve here's what I did to fix it.
I put a felt type washer/seal and it still lets it breath but took away the hissing.
The notch moved to atmosphere when you slide the heater **** to hot. Releasing the vacuum on the heater hose valve.
Its supposed ti "leak" by disgen.
Hope this helps someone in the future.
Car: '84 Berlinetta,
Engine: 5.0 liter
I realize this is an old thread, but I'm hoping someone will help me out with either a part number or a parts source. My vacuum selector valve was leaking as discussed in above posts. when I tried to remove it to do the repair shown in the video the little star shaped spring fell out and into the abyss under my console. can't find the spring. willing to buy a whole new one if I could find one. Mine is a 5 port. No amount of "Googling has turned up the right one yet.Please help if you can. Thanks.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
It's not in the abyss, it's the floor of your car. Take the console out and go after it.
