Radio Noise Capacitor?
Car: '82 Camaro Z28
Engine: 5,7l (GM Crate Engine(?))
Transmission: 3 Gear Automatik TH350
Axle/Gears: Borg Warner 9 Bolt, 2.77
when I my Camaro yesterday started and made the radio on came strange noises from the radio. the noise with the increase speed louder. And my interior lighting no longer works. someone had this problem?
am pleased about each tip.
Car: 90 Formula / T-tops
Transmission: MD8
Re: Radio Noise Capacitor?
Did your interior lights stop working when your radio noises started? What kind of radio do you have? Is it stock?
Here are some good tips:
http://www.crutchfield.com/S-Qn8uUsk...ion_guide.html
Car: '82 Camaro Z28
both problems came together. Could it be because I had the ignition for a long time. I have the original radio
Car: '82 Camaro Z28
I have been working on the car and the ignition was on. Then I had this problem
Car: '82 Camaro Z28
The switch for the tailgate also no longer works
Transmission: MD8
After making sure you did not blow fuses somewhere, I'd first fix the light problems. That may solve your radio problem.
Car: '82 Camaro Z28
The fuse looks ok. But I will check again after work.
Thanks for your help.
Car: '82 Camaro Z28
OK. It works again...everything. A fuse was broken. Only with the eyes i have not see. Have it measured. The radio also works again...without noise. why? ... I do not know ...
thanks again ...
I go drive my car :-)
thanks again ...
