Removing Aftermarket Alarm System - Cut Wire to Starter??
Car: 1987 Camaro Z28
tl;dr - when removing aftermarket alarm, I don't know how to wire these to get the starter to turn over. The whole story:
I need a little assistance. So I'm removing one of those horrid aftermarket alarm systems from my car. I've gotten to a point where almost everything is out, except I've done something that won't let my car start - basically it seems as if I've cut the wire from the ignition to the starter (or distributer) I think. I've attached a picture of the wires in question for reference.
Essentially, I have three wires sticking out that I have no idea what they do. The blue circled and red circled wires, when spliced, enable the starter to turn, but when I let go of the key the ignition doesn't stop until I turn the key to acc, and the car never starts. The blue circled one was spliced in and I can't figure out the wire it's spliced to. Then the yellow circled one hangs out and I can't figure out what it does.
Just fyi, the red circled one is a smaller violet wire with a white stripe, the blue circled wire goes into the casing and I don't know what wire it's spliced to, and the yellow circled wire is a thicker violet wire with a black stripe.
(For location reference, this is on the firewall, the brake booster is on the right side and the driver's side valve cover is on the left...)
Re: Removing Aftermarket Alarm System - Cut Wire to Starter??
The large purple wire , the one with the small length of black wire soldered to it , is for certain the one going to your starter solenoid . You need to find the other end of that wire in the harness , a exact same sized and colored wire , and rejoin them using proper wire splicing method . Maybe that smaller purple wire is also someone's soldered in wire extension and that is the big purple you need ? Have you connected just the big and little purple wires together and not connecting the third heavy black one and seeing if the starter functions normally ? In other words , connect the red and yellow circles without connecting the blue circle in with them ?
Car: 1989 trans am gta /2001 Jeep wj
Having just found one of these systems in my car ill post the diagrams I have saved. The previous owners of my car just jumped the white with red stripes too the solid white wire and It runs fine.
Received 1,672 Likes
Best thing to do is to peel back the split-loom, find all the original wires, and hook them back up where they came from, color to color. Eliminate ANY AND ALL aftermarket wiring by following it to its ends (BOTH ends) and cutting, disconnecting, or whatever, and putting whatever factory wiring went to things, back. GET RID OF IT ALL. Isn't usually too hard to tell OE from AM wire; AM is almost always inferior thermoplastic insulation.
I would not "jump", "splice", "cut out", or otherwise sodomize ANYTHING. Put it all back just like it came, as much as possible. Use solder (with rosin-core electronic solder, NOT acid-core plumbing solder) and heat-shrink, preferably the adhesive-lined "marine" type, on everything if possible. Might have to add in a short section here or there to make up any length that the rapists cut out. Make sure you use the same gauge the factory used, or, at least, no smaller, and not too terribly much larger. Wouldn't hurt to use the same colors if you can find it.
In your photo the shiny black wire with the white just below the insulation surface, is not factory. ELIMINATE THEM. Find where they go and RIP THEM OUT.
Thank you guys! I got it all figured out - the smaller pink one was another aftermarket, and I did finally find where that black one connected back to the starter wire. It's gone - all of it - and it looks great, despite my having to splice new wire in because they cut out about 4" of the original wire . Thanks again!
Wiring is one of the eeeeeeeeezyest things in a car... once you decide you are no longer intimidated by it, it's a piece o cake.
Glad you got it handled!!
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I had one installed and after a time it started acting up.
I took it to a respectable shop and had it all removed for $40.00.
When he handed me a box with it in side it looked like 40 feet of wires and relays, censers, etc. What a mess.
If you want it all gone then pay a pro to do it in 30 minutes and be done with it.
I'm glad I did. I do not like the idea of having all that crap still in there.
