Tons of aftermarket stuff!!! garage sale!!
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
Garage sale/car part out, all prices DO NOT include shipping from Logan, Utah 84321. If using Paypal buyer will add 3% for fees. Text or email is the fastest way to get a hold of me! I do have pics of most everything, if I don’t I can get them no problem, text me for pics not listed in the Ad.
Summit dual core aluminum radiator, direct fit for 3rd gens, with stock fan and custom shroud $100 ****SOLD****
Hooker super comp headers #2210, coated then painted black some damage to one of the primaries, nothing that hurt performance: $150 ****SOLD*****
(4) 235/35/18 tires for drift/burnout: $30 full set
F41 package 34mm front sway bar: $15
4th gen firebird dash: $75
(2) Weld RTS wheels, chevy pattern, 15x10, 6.5'' BS with 315 M/T drag radials $450
Summit single kickout steel oil pan for SBC part # SUM-G3507X: $25
Stock for 9’’ center section pretty sure its an open diff, 31 spline, unknown ratio $50
MSD blaster 2 coil, works fine but looks alittle rough $15 ***sold***
Front suspension:
Strange Single adj Front shocks
Racecraft 4130 Race K-Member
4130 Racecraft Inc. 13" Rod End A-Arms
4130 2" Drop Spindles
Racecraft Camaro Steel Caster Camber Plates
Racecraft Pinto Rack and Pinion
Racecraft Inc. Light Weight Tie Rod Kit
Racecraft bumpsteer kit
Front end Limiter Kit
Strange Drag Race Brake kit
RaceCraft Coilover kit
Braided brake lines
Racecraft Steering shaft kit
---$2500 for everything, $3000 shipped. would like to sell as complete package.
Rear suspension:
9in Housing backbraced, stock width, Wolfe anti roll bar welded to housing, madman shock mounts, LCARB's welded on, fill and drain holes. $700 for housing. ***SOLD****
***Strange UltraCase with 40 spline spool, 3.70 pro gear, ring for speed sensor, $1100 SOLD*****
Moser 40 spline axles, Star flanged and gun drilled stock width $300 ***SOLD***
Burkhart chromoly offset LCA's $125
AFCO Eliminator double adj. rear shocks part number 3870R, only 15 passes on them. $250 ****SOLD****
Burkhart short Body mount TQ arm. with Custom built Mount to clear ultracase, will also come with stock mount for stock rear ends $250 ***SOLD***
Qa1 150lb springs 12" $45
Aerospace drag brake kit for new style big bearing ford $300 ***SOLD***
Burkhart chromoly adjustable panhard bar $75
thanks
Colt 435-760-8178
Front suspension:
Braided brake lines
Rear suspension:
thanks
Colt 435-760-8178
Car: 00' rcsb
Transmission: 4l80e
Re: Tons of aftermarket stuff!!! garage sale!!
I am everywhere lol, there is a pending sale on the cell, if it goes through I will have pics for you tonight
Pics of wheels/Tires combo please.
Also interested in the Strange brake kit if you decide to part the suspension stuff out.
Car: 1987 IROC
Engine: 5.7 TPI
Axle/Gears: 9 bolt 3.27s
what all does line-loc consist of? wires, switch. lines, what?? and how well does it work. my master cly is different, so don't need that.and shipped to 85735 AZ. Thanks ..
Car: 00' rcsb
Transmission: 4l80e
I will have to measure it for you, I will get those for you when I head out there
Want a title? Post!
Car: 91z28/91firebird/02grandam
Engine: L98/3.1/3.4
Transmission: 700r4/5spd?¿?//?
Axle/Gears: 3.23?¿?I think/?
How much headers shipped to Ky 41101? Thanx.
Car: 1982 Z28 Camaro
Engine: 383 Stroker
Transmission: TH350
Interested in the 2210 headers if still available and the pictured gauge panel. Cost to ship to 78727?
Car: 86 Z
Engine: 400 sbc
Transmission: t-56
Axle/Gears: 4.10
Just let me know about the intercooler... I'll take it for sure. 734-558-8664.thanks. -Ray
Car: 91 RS
Engine: 355
Also interested in the headers shipped to 44077 of still available and if any pending sales fall through.
Car: 89 RS Camaro
Engine: 355, G1 trickflows, XR282HR
Transmission: TKO 600
Axle/Gears: Strange 12 bolt/4:10
How much for the anti roll bar to 27330?
Engine: 4++,350 & 305 CIs
PM sent
Car: 00' rcsb
Transmission: 4l80e
Dash does not have gauge cluster or radio trim plate, other then that it's all there
1992rs/ss
16
01-28-2016 09:58 PM
92camaroJoe
08-13-2015 06:07 AM
