CTS-V Rear conversion brackets 10 bolt or 9 bolt
I have several of these brackets and can be used with or without parking brake. (9 bolt/10 bolt/12 bolt/ford 9 inch) The steel brackets are 80. for a pair and the park brake spacers are 125 for the pair. I also have a full all aluminum CNC version for the 10 bolt only that i can let go of for 315/set. all brackets come with the needed hardware. I have 2010+ Camaro SS rear conversion brackets as well just PM me.
Car: 1986 Z28 Iroc
Re: CTS-V Rear conversion brackets 10 bolt or 9 bolt
So what size rotor can you run with your brackets? Plus are you using rear CTS-v calipers?
The rear rotor size is 14.4 inches (stock 09-14 ctsv rear rotor OR 2010 and newer Camaro SS rear rotor) The are the same part # and both these rotors need the center hole opened to fit over the axle eccentric (2.75-2.78) . CTSV rear calipers are what to use, preferably the Gen 2 calipers (09-14) but the 04-07 can be made to work as well.
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
nice.. just curious, what size rim would you need to fit these?
evilstuie
01-09-2020 08:29 PM
355tpipickup
08-25-2015 12:54 AM
