[TX] Lloyd Elliott AFR 1040's, 1205 TPIS Miniram, Dyno Don single cat headers
Old 08-18-2015, 10:27 PM
LT1Formula's Avatar
Parting my build I was planning. All parts are NEW.
NEW AFR 1040's 65cc heads full intake/exhaust porting by Lloyd Elliott (Elliott's Portworks) Lloyd is one of the best hand porters out there. I had a set last year done by him that flowed about 310/230 at .600 and had the same porting done this time. 2.05/1.60 valves, .600 lift AFR springs. SOLD.
TPIS 1205 miniram intake with rails, throttle cable bracket, FPR, and bag of bolts I got from previous seller. No fuel lines or water neck. Intake needs a wipedown but has never been used. SOLD.
NEW Dyno Don 1 3/4 headers with single cat Y pipe. No AIR. $625 plus shipping.
Old 08-19-2015, 03:14 AM
IBrockZ's Avatar
Car: 87 irocz 305 5.0 5 speed G92 option
Engine: 305 tpi
Axle/Gears: 9 bolt 3.45 factory gears
Re: Lloyd Elliott AFR 1040's, 1205 TPIS Miniram, Dyno Don single cat headers
Wow those heads are sweet wish I could afford this stuff. I live in CA with the smog *****... :/ I don't think we can have Mini Ram here. I hear great things about it tho! GLWS.
Old 08-19-2015, 11:32 AM
toronto formula's Avatar
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
Does a mini ram fit under a stock formula hood- or do you have to modify
Old 08-19-2015, 03:10 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
It fits under every hood GM made for TPI cars.
Old 08-19-2015, 07:48 PM
LT1Formula's Avatar
Thanks man I appreciate it.
True story.
Old 08-21-2015, 06:59 AM
renegade69's Avatar
PM sent
Old 08-21-2015, 09:17 AM
LT1Formula's Avatar
Heads and Headers have been sold.
Miniram is pending awaiting payment.
Old 08-21-2015, 09:23 AM
renegade69's Avatar
Done.
Thanks again
Old 08-23-2015, 09:27 AM
z28yourstang's Avatar
Car: 1986 z28
Engine: 350 hsr
Transmission: probuilt 700r4/edge 2800
Axle/Gears: stock 4th gen 3.23
Is mini ram sold?
Old 09-23-2015, 12:53 AM
LT1Formula's Avatar
Deal fell through on the heads and headers so they are available again.
Old 09-23-2015, 05:39 AM
TGO Supporter/Moderator
anesthes's Avatar
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Whats the runner volume after porting?
-- Joe
Old 09-23-2015, 04:21 PM
SUPER CHEVY66's Avatar
Car: 92 camaro, 06 trailblazer ss
Engine: 5.0 tbi, 6.0 ls2
i will take the heads.
Old 09-23-2015, 11:55 PM
LT1Formula's Avatar
-- Joe
Hey Joe. I did not have the runner volume checked after porting.
Pm sent.
Old 09-24-2015, 12:17 AM
92rszz4's Avatar
Car: 92 camaro RS
Engine: zz4 craite engine with TPI set up
Axle/Gears: 10 bolt 3.42 posi
pm sent for AFR heads
Old 10-08-2015, 04:23 AM
FerrMaro's Avatar
Have the heads been sold?
Old 10-08-2015, 05:37 PM
the heads are sold and thank you to LT1formula.
Old 10-21-2015, 04:38 AM
88BlackZ-51's Avatar
Why did u get these ported?
Old 10-22-2015, 08:20 PM
LT1Formula's Avatar
These heads are great out of the box but Lloyd can make them better. The first set I had him port flowed 310/230 @.600 with a 1205 intake port.
Old 11-06-2015, 10:42 AM
LT1Formula's Avatar
Still have the dyno don headers.
Old 11-06-2015, 04:25 PM
Necron's Avatar
Car: 2002 Camaro SS
Engine: Built LS
LT1Formula what is the lowest you will go on shipping too 45231. You can PM if you want.
Old 11-14-2015, 12:02 AM
LT1Formula's Avatar
Headers SOLD.
85Iroc-Z
08-13-2015 01:58 AM
89mulletbird
08-12-2015 07:08 PM
Sanjay
08-12-2015 03:41 PM
89mulletbird
Southern California Area
08-10-2015 10:16 AM
drathaar907
08-06-2015 04:20 PM
Quick Reply: [TX] Lloyd Elliott AFR 1040's, 1205 TPIS Miniram, Dyno Don single cat headers
