[IN] *NEW* Built 700r4 - 700hp/700tq - Includes 3600 Stall *NEW*
Want a title? Post!
Category: Drivetrain
Price: $1450
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V, 67-92 Chevrolet Camaro, 67-92 Pontiac Firebird
Location (State): IN
Item Condition: Brand New
LS Engine?: Fits LS Engine
219-476-6919
andrewporter1987@hotmail.com
Kouts, IN 46347
700r4 Transmission (EVERYTHING BRAND NEW)
Reworked valve body and completely gone through to make sure there are no stuck valves
Raybestoes Z-PAK with 13 clutches (replaces the factory 5 clutches in the 3-4 drum). The Z-PAK is made up of heat treated steels that withstand more heat, delivering longer transmission life.
Raybestoes high temp energy clutches throughout the rest of the unit, along with all new steels, bushings, and rings.
A Sonnax .500 boost valve (insures nice crisp clean shifting with no delays).
4140 hardened pump rings
Teflon Pump bushing
13 vane pump rotor
29 element sprag
Sonnax Wide Open Throttle Valve
Sonnax Beast Sunshell
Hardened input shaft and drum
3" wide heavy duty Kevlar band
Corvette servo
5 pinion planetary
Blocked off the 1,2,3,4 accumulators to give a solid, firm, and crisp shift. Discarded the springs in the accumulator to eliminate problems associated with springs breaking
Manual reverse valve body
3600 stall converter
Large transmission cooler
Transmission dipstick
Inspection cover
$1,450
NOT INCLUDED BUT AVAILABLE:
B&M stealth pro ratchet shifter (brand new)
TCI flexplate with ARP bolts (brand new)
700r4 poly mount (brand new)
Price: $1450
219-476-6919
Kouts, IN 46347
Teflon Pump bushing
13 vane pump rotor
29 element sprag
Corvette servo
5 pinion planetary
Inspection cover
$1,450
Want a title? Post!
Re: *NEW* Built 700r4 - 700hp/700tq - Includes 3600 Stall *NEW*
I have someone interested in the whole package right now. He will want the shofter included. If he doesn't buy it, I will do $300 on the shifter.
Car: 1989 camaro
Engine: 355 tpi
Transmission: 700r
Axle/Gears: 3.50
what brand convertor comes with it?
Want a title? Post!
HAhaha. Andrew, I can't believe you're in Kouts. I'm from LaCrosse and I've got a 1979 Corvette that's currently in LaCrosse and has a 4L60e going into it TODAY....
If we would've crossed paths a month ago there's no question I would've taken this off of your hands.
Having said that there's a guy over on the Corvette Forum who's buying a 383 Crate Motor currently and he's got plans to have his 700r4 rebuilt to handle the power; I'm going to direct him to your post over here...
Adam
LaCrosse High School -Class of '99
Adam
slowass94lt1
01-09-2016 06:47 PM
leeperryracing
02-02-2011 04:01 AM
Orr89RocZ
01-04-2009 05:21 PM
