[MA] Vortec Stealth Ram
Old 05-27-2016, 07:17 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Vortec Stealth Ram
Comes with the fuel rail kit with adjustable regulator and fp gauge and arp manifold bolts. Asking $650 minus the injectors. Injectors are brand new 36lb Holley Injectors never run. Paid $350 for the set. Manifold and injectors $800 obo.
Old 05-29-2016, 08:49 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Re: Vortec Stealth Ram
Bump
Old 06-02-2016, 07:17 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Bump
Old 06-02-2016, 11:04 PM
Mr.ChevyStroker's Avatar
Car: RS Camaro
Engine: 97 L31 350:Eventually a stroker
Transmission: WC T-5
Axle/Gears: Zexel Torsen 3.73s
Do any of the factory you parrts work on this stealthram? Fuel rails injectors harness.. Anything else?
Old 06-03-2016, 05:34 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Everything plugs in. Comes with its own rails and the throttle body and cruise control bracket. You can use any injectors you want.
Old 06-03-2016, 10:52 PM
Car: RS Camaro
What's an offer just for the stealth ram itself with the throttle body? I have a while tpi set up essentially, just not the intake set up
Old 06-04-2016, 02:04 AM
Car: RS Camaro
It would be the bracket, TB and the bolts. And does the adjustable fpr work on sto
ck rails?
Old 06-04-2016, 04:34 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
ck rails?
it comes with everything pictured. Intake, fuel rails, no tb as you use your own. It comes with its own fuel rails.
Old 06-04-2016, 09:53 AM
Car: RS Camaro
So no separating the items?
Old 06-04-2016, 12:59 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
I can seperate the injectors. You need the fuel rails. As they are made to fit only the stealth ram. Factory tpi rails wont work.
Old 06-05-2016, 11:56 PM
Car: RS Camaro
Was this setup uses with a speed density set up or a MAF set up also? If I would be purchasing this it would need to be able to work with the maf set up because the IROC I have is a 85
Old 06-06-2016, 03:01 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
It is for either maf or speed density.
Old 06-06-2016, 03:36 PM
jclopezz's Avatar
Car: 1991 Z28
Transmission: WCT5
Axle/Gears: Positive 4.10
Does anyone know if this is California emissions compliant? And would it clear the hood on a 1991 Z28?
Old 06-06-2016, 04:22 PM
vtwinsroc's Avatar
Car: 86 iroc,89iroc,98z28
Engine: 305,305,ls1
Transmission: 700r4/4l60e
Axle/Gears: 2.77/3.23
No cause no egr ..and no it won t fit under a stock hood..
Old 06-06-2016, 04:28 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
It fits camaros, not firebirds. No egr either
Old 06-06-2016, 05:39 PM
jclopezz's Avatar
Car: 1991 Z28
Transmission: WCT5
I appreciate your prompt response.
Old 06-09-2016, 07:13 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Bump for sale. Make offers
Old 06-09-2016, 03:32 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
Bump
Old 07-07-2017, 09:44 PM
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Originally Posted by IROCZ1989
Bump
Old 07-08-2017, 12:12 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
For anyone who is curious, these are no longer in production and the fuel rails with the adjustable regulator are also no longer available at all.
Old 09-20-2017, 12:15 PM
Captainfernny's Avatar
Car: 1988 GTA Trans Am
Engine: 5.7
Still available? Is this the same one as P/N: WND-7540?
HerpDerp1919
06-18-2021 01:03 AM
dmccain
04-23-2016 12:49 PM
HeinzK5
04-16-2016 06:35 AM
DonW
Carburetors
24
04-08-2016 10:53 PM
instaldave
04-07-2016 06:14 AM
Quick Reply: [MA] Vortec Stealth Ram
