[QC] Wanted...Front 1le Brake Brackets
Old 02-23-2016, 01:04 PM
lugercollector's Avatar
Car: 92 Formula
Transmission: BW 5 Speed
Need front 1le brake mounting brackets ......including caliper holding brackets
GM part numbers #18016034 x2 (spindle adaptor plates) as well as rh#10132830 and
lh#10132829 (caliper mounting plates)
Old 03-21-2016, 05:24 PM
Car: 92 Formula
Re: Wanted...Front 1le Brake Brackets
GM part numbers #18016034 x2 (spindle adaptor plates) as well as rh#10132830 and rh#10132829 (caliper mounting plates)
Old 02-12-2017, 09:02 AM
Car: 92 Formula
btt
Old 03-12-2017, 03:57 PM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
I have those including both spindles removed from a 89 TTA. These are GM parts not the reproduction parts. Very hard to find. I would prefer to sell it all together. New hawk pads included. I don't have the PBR calipers but I believe you can still buy rebuilt ones. Some of the bolts are missing but could be bought from GM the last time I checked. A friend and I removed these and he lost some of the bolts and sold the PBR calipers before I bought them from him. These have been boxed up and stored inside for over 9 years now. The right price will get these from me. I do have pictures I took before boxing them up years ago.
Old 04-01-2017, 12:45 AM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
Dokken, can you post the pics, not interested in buying just need a good pic of the bracket.
Old 04-01-2017, 07:42 AM
Dokken10's Avatar
Car: 91 Formula
What exactly are you looking to see and why? If you are looking to see the difference between GM and aftermarket, GM has dimples that lock them together and aftermarket does not have the dimples.
Old 04-01-2017, 12:23 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
just wanted to see the a pick of the bracket got an idea of making some to mount a brembo caliper
Old 04-01-2017, 01:08 PM
Drew's Avatar
Received 1,052 Likes on 748 Posts
Have you tried Google? Not to be a ********, but there are several pages detailing the 1LE brake swap, including plenty of photos of the OEM parts. It's also worth looking into big brake upgrades, since there are lots of pages detailing what is necessary to fit various setups. Nearly any change in calipers or rotors requires a unique bracket, and many already have been designed and patterns shared.
Old 04-01-2017, 03:26 PM
Dokken10's Avatar
Car: 91 Formula
Not mine and these are aftermarket. Wanted...Front 1le Brake Brackets-1lebracket2web.jpg
Old 04-01-2017, 03:27 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
The brembo caliper mounts are completely different than a 1LE and have been done so it will be easy to do.
https://www.thirdgen.org/forums/hist...s-trans-4.html
Old 07-19-2021, 05:15 PM
Guest
Guest
Posts: n/a
Do you still have any of those 1LE brake parts? I need two of #18016034. Thanks. 803-401-5288. Luke.
skirocz28
Interior Parts Wanted
02-14-2016 09:50 AM
mr_han_solo
02-11-2016 11:49 PM
Immrpablo
02-07-2016 05:23 PM
eliofall
Brakes
02-06-2016 07:32 AM
L-Train8
02-05-2016 03:30 PM
Quick Reply: [QC] Wanted...Front 1le Brake Brackets
