1992 350 tpi
Old 02-11-2007, 03:33 PM
gta87ls1's Avatar
Car: 1987 Pontiac GTA
Engine: 350tpi
Transmission: t56 6 speed
Axle/Gears: 3.70
1992 350 tpi
I just recently purchased a 1992 350tpi from a camaro. I got the harness and computer with it. Right near the connectors to the pcm theres a clear looking connector with about 16 wires. What does that connect to, im assuming it would be for vats which i did not get with it. Also the vats module is there another harness from that to the key? Any help would be appreciated. Also the connector on the firewall on the drivers side, should mine from my 87 trans am plug right into that with no problem or did they change that harness over the years?
Out-Cast
08-17-2015 10:57 AM
Jlanz55
08-17-2015 07:15 AM
bamaboy0323
08-15-2015 07:20 AM
wruiz
08-13-2015 09:07 PM
gta power
08-13-2015 06:15 AM
Quick Reply: 1992 350 tpi
