building a sscca l69 track car (anything is possible)
Old 12-28-2009, 12:58 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
My first car my parents anversery car has over 350k on body thats 300k on l69 ho305 about 48k on crate 350 and 2k on dz302. i sold the 302 for a dp on wifes new car so the build starts over.
motor that is a test motor i got for a 100$ and some bbc parts
010 4 bolt main block with around 60k
all new gaskets, trw .030 over pistons pink rods and a steel crank
i put a mild cam and a noise gear drive just for the heck of it.
a edelbrock highrise and a holley carb. it has camlehump heads
everthing sprayed black
383 i am building for a t-60 or bigger set up and have not made up my mind yet.
forged 383 crank with blancer and flywheel (got already)
eagle rods 5.7
010 block (have and ready to be machined)
I had a set if 64cc tall camlehump heads with manley stainless valves 2.02's machined in fully ported and polished comp valve springs and good retainers and and roller rockers and push rods guides
piston unknown
cam unkown
mls head gaskets
arp everything
I am building the car for a open track or autocross just a trailer queen that i can drive if wanted... you know 2 seats a cage and a ton of power with good rubber and good suspension. i plan to runs the 350 as long as i can and finish the 383 with the turbo set up. times are tight since i just had my first baby girl. i will build and tig my own stainless manifolds and do as much fabbing and take pics as much as i can to show the progress.
these plans might change since i migh have talked my father out of a 454 with scat rotating assembly
Old 12-28-2009, 01:00 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Re: building a sscca l69 track car (anything is possible)
sorry for the dirty shop pics its in a mustang speed shop so you know surrounded buy dead fords
specialized
06-18-2022 09:26 AM
SiCkRs
Members Camaros
32
07-01-2018 04:53 AM
Azrael91966669
25
06-20-2017 04:04 AM
Reborn756
09-04-2015 03:42 AM
jharrison5
08-19-2015 05:53 PM
Quick Reply: building a sscca l69 track car (anything is possible)
