Engine Swap Help
Old 03-09-2012, 08:52 PM
Angelduran5858's Avatar
Car: 87 Camaro Z28
Axle/Gears: 4th Gen 3.42
Engine Swap Help
Alright I Been thinking about either doing a complete engine swap on my 87 camaro z28 it has a stock 305 4bbl witch has been giving me lots of problem
Do you guys think I should do an engine swap to an LT1 from a 94 z28 camaro??
or should i just convert to TPI???
also witch will be easier??
Old 03-12-2012, 06:46 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Both would be about the same difficulty, except for the "Los Angeles, CA" part. Either way, you are going to have to swap over every little piece that was part of the emissions equipment that came with the car from which the swap is based. TPI will mean the whole system, plus the whole exhaust.
The easiest by far should be getting the carb up to snuff. They aren't that complicated.
Frozer!!!
01-19-2024 04:55 PM
camaro11j
09-19-2018 08:49 AM
theshackle
03-05-2017 06:37 PM
sreZ28
08-14-2015 07:48 PM
bradleydeanuhl
08-12-2015 11:48 AM
Quick Reply: Engine Swap Help
