GEN III Build - 383 Stroker / T56 combo
Old 10-17-2016, 06:21 PM
GMan2012's Avatar
Car: 1988 Chevy Camaro
Engine: 2.8L
Looking to start this project here in the next few months, looking for advice and tips. This engine / transmission a good combination? A little of a newbie if you will. Any and all advice and or recommendations are appreciated!
Old 10-28-2016, 02:13 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: GEN III Build - 383 Stroker / T56 combo
The money you would waste on a stroker would go a lot farther with a turbo. The T56 you would need, from a 98-02 Z28, is scarce, in high demand, not cheap, and not that strong. Better to do a used 4L80E with a TransGo HD2 kit, and a 4.3 converter from a 97 C2500 van. All readily available, cheaper and stronger, plus less work.
Old 11-01-2016, 10:27 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
you will want to upgrade the from the stock rear to something stronger. If you drive on the street most of the time that will help keep the 10bolt alive longer.
Old 11-03-2016, 01:20 PM
GMan2012's Avatar
Engine: 2.8L
Cosmick: I like your suggestion of a turbo instead of stroker kit. With the transmission though, I had wanted a manual tranny. The 4L80, although some people have converted them to automatic, seems to be a bit of a task! Am I wrong?
Yaj: Yeah, I do plan on upgrading the rear end! That is one thing I almost know nothing about however, suggested gear ratios, rear ends, etc?
Old 11-03-2016, 09:40 PM
yaj15's Avatar
Car: 1988 IROC-Z
Aftermarket 12bolt should be strong enough. Are you going to use a T56 or an automatic. The gears have to be matched to the powerband of the engine you are using. Do you have specs on the cam?
Old 11-28-2016, 10:07 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I realize I'm jumping in a little late here, but by "GEN III", are you talking about the car, or the engine?
Old 11-30-2016, 01:05 PM
blkbrd84's Avatar
Car: 1984 Trans Am
Engine: 350/357 Chevy
Transmission: 5 Speed Manual
Axle/Gears: 3.73 Posi
I've been looking at a similar swap for my 84 HO TA 5spd. I am considering a GM crate ZZ6 or 383, and keeping the stock trans/rear end for phase 1. Poor thing has been off the road for 20 years!
Old 01-18-2017, 08:20 AM
GMan2012's Avatar
Engine: 2.8L
wanting to use the T56. I would prefer manual and seems to be one of the best, still available manual tranny's out there. Any other manual suggestions? Also, no I do not have the specs on the cam, still in the researching phase. Trying to find the best bang for the buck!
The car. 1988.
Yeah, the more I look into it and whatnot looking like a built 350 would be around the same price and sometimes a little more HP. Not sure though.
Old 01-18-2017, 09:46 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
I guess I didn't abuse my 10 bolt enough...or I have been real lucky. At least 300 passes at the track (and who knows how many by the previous owner). Most of those passes in the low 12's and high 11's. Never a single failure. It is an auto, so that helps.
If you are looking for a driver, I would do the 383 and the T56. You'll be happy. If you are trying to build a drag car, then the 282/T56 combo is not the best course.
Old 01-18-2017, 10:38 AM
GMan2012's Avatar
Engine: 2.8L
Looking for something to mainly drive around with a few possible track passes... recommend 383/T56 combo over 350/T56 combo?
Old 01-18-2017, 11:12 AM
pancherj's Avatar
Car: 1990 IROC
If you have to rebuild the engine, go 383 (same cost). If you find a good-running 350, go with the 350. I had no trouble getting my IROC into the 11's with a lowly 350.
Zylinder
10-02-2016 11:57 AM
Gangsta Stude
09-26-2016 12:23 PM
Toad1
09-22-2016 10:04 AM
Arctic White 91 RS
Aftermarket Product Review
09-19-2016 06:59 PM
DirtShaman
09-18-2016 12:52 PM
Quick Reply: GEN III Build - 383 Stroker / T56 combo
