Thanks thirdgen!
Old 11-20-2016, 03:32 PM
Josh F's Avatar
Car: 85 firebird 350 .30 over 650 Holly.
Engine: 355.rollers.650 Holley. Thumper.cam
Transmission: V6 14 spine t5 .wouldn't recommend
Axle/Gears: 3:43 ls gotta be changed
Thanks thirdgen!
Just got my 85 on the road today.dropped a 30 over 350 in to the originally v6 car.my first build ever .i am mechanically inclined but never done anything like this with no help other than yall.and a buddy helped rip the old engine out.ive spent hours researching this site and it paid off.got a little more to do under the hood but runs drives great.thanks for all the help thirdgen
Old 11-20-2016, 03:35 PM
Josh F's Avatar
Re: Thanks thirdgen!
Pulling the v6
Old 11-20-2016, 03:40 PM
Josh F's Avatar
After i got my 355 put back together
Old 11-20-2016, 03:44 PM
Josh F's Avatar
Engine in
Old 11-20-2016, 03:47 PM
Josh F's Avatar
Old 11-20-2016, 03:50 PM
Josh F's Avatar
Today after my first drive..little snow on the ground
Old 11-20-2016, 07:43 PM
M G Brewer's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77
Looking good!
Old 11-20-2016, 08:20 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
good job, i'd replace those rubber fuels lines if it were mine thou.
Old 11-21-2016, 07:31 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Looking good man!
Old 11-21-2016, 07:37 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
Nice job-hows your T5 holding up?
Old 11-21-2016, 06:25 PM
Josh F's Avatar
T5s holding up pretty well..gears till 3rd seem really short.clutch dost slip but I grinded rather than cut the input shaft unroll it fit nice an tight.got a lot of clean in up to do under the hood but I'm just stoked to have it on the road again
Old 11-21-2016, 06:32 PM
Josh F's Avatar
Ment to say clutch dosnt slip..but I ain't gonna dump it by no means you can till it's weak.havent had it dynoed but my set up is running around 360 75 .statistically. once I get outta second seems like I can get on it good ..advice would be great
Old 11-23-2016, 10:31 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Third gear is one of the T5 weak links. Be gentle with third.
Old 11-23-2016, 10:32 AM
cosmick's Avatar
Too much axle ratio. Try a smaller-number axle ratio. Like if you have a 3.42:1 axle, try a 3.08:1 axle.
Old 11-23-2016, 12:04 PM
Josh F's Avatar
What do you think about 3.73s? In the rear?
Old 11-23-2016, 03:40 PM
cosmick's Avatar
If both first AND second seem too much with a 3.42, then you would really hate a 3.73
I know it seems like everyone else chooses a 3.73, but that alone doesn't make it a good choice for you, and probably for a fair number of them, either.
For some of them, it's to get a certain cruise rpm without changing the transmission. For others, it is to get a desired rpm in their 1:1 transmission gear at the end of a 1/4 mile drag strip. And the rest are me-too, monkey see, monkey do. Don't be one of them.
Old 11-23-2016, 04:09 PM
Josh F's Avatar
So second isn't quite as bad as first.but not great.3k rpm at 20_25 mph.so what would the 3.08 be like?
Old 11-23-2016, 04:59 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Brave man.
Kudos!
I want to do this someday when I grow up.
I need a garage so bad.
...and one of these
Old 11-23-2016, 05:04 PM
W.E.G.'s Avatar
Engine: V6 2.8
...although in my heart of hearts, I more need one of these one time in my life while I'm still on this side of it.
Old 11-24-2016, 04:18 AM
cosmick's Avatar
Here's how to figure it out for yourself. First, you need to know the transmission ratios. For a V8-spec T5, they're 2.95/1.94/1.34/1.00/OD, either 0.73 or 0.63.
Then you need to know the effective diameter of your rear tires, which is 97% of their advertised diameter.
Now the math.
Trans ratio times axle ratio times 336 times mph, divided by effective diameter. That gives RPM.
First calculate what you already have to get a baseline. If it doesn't match what you observed, then either your speedometer is off, or your tach, or the axle ratio isn't what you thought.
But after playing with the math for 20 years, I gave up on most of it and started doing what most guys just do all along. Drive it as it is, if it seems too much then try a taller gear, if it seems too lazy try a shorter gear.
Finding a complete used 3.08 assembly is cheaper and easier than swapping 3.08 gears into an axle already fitted with 3.42s, then if you like how the 3.08s drive, add a limited slip to that. '90-up LO3/T5 came with 3.08:1 and 28-spline shafts. Older axles are only 26-spline. '85-up are 7.625" ring gears, pre-'85 were 7.50".
If you already have a limited slip and a 3.42:1, then you would need a different limited slip for the 3.08s.
If you adapted the v6-spec T5, then forget the axle and get the correct T5.
Old 11-30-2016, 09:16 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
What did the car dyno out of curiosity?
Old 11-30-2016, 10:50 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
...with no help other than yall...thanks for all the help thirdgen
Good to hear!
I can honestly say I have learned more from this site than from my previous 30 years of wrenching. And not just about 3rd gens, car tech in general.
Old 12-02-2016, 07:33 AM
Josh F's Avatar
I haven't had the car dynoed.im only able to look at it from a statistical standpoint for my set up of the engine right now.so I would feel very safe to say around 350- 60 hp harder to figure out torque just to many variables
