Which exhaust bends
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Which exhaust bends
I've decided to build my own 4" cat back exhaust. Mainly due the cost of shipping it the UK. Has anyone else built one in 4" or 3"? What I'm asking is for a materials list, for example, how many of which type of bend, how much straight pipe, which muffler etc. Thanks
Car: '92 RS Camaro
Transmission: TH400
Re: Which exhaust bends
Short headers, Ive built a Y pipe, will probably build another in 3". So roughly starting from where a typical Y pipe stops? No cats
If you do ypipe in right location starting with flowmaster y merge there should be about a 45 deg bend to angle pipe down driveshaft tunnel. Thats gonna get you 2.5-3 ft of straight before the bend up over axle which will be 1 90 bend you may trim back to a 60-70 deg angle or so? Then another 90 to complete the over axle. 1 more 90 for turning exhaust towards driver side rear fender. Muffler under gas tank. 90 deg off muffler for tail pipe.
Or you go under axle like i did my 5". Still clears well and is abit easier to do in my opinion. Kinda go 3 ft straight back, slight 45 toward pass side then big bend back towards driver side to go into muffler under gas tank.
Various layouts you can run. All in all roughly 1 45, 3-4 90's and 2-3 ft straight aint a bad starting point
Car: '92 RS Camaro
Transmission: TH400
Wicked, thanks a lot! Ill look at the sizes right away. 5" under the axle? Is your car lowered? Im using a Moser 9"
Car: '92 RS Camaro
Transmission: TH400
I did think about oval, but would again have to ship from US. I can get tight radius bends, would these be better?
david068513
09-18-2015 10:36 AM
