Weld or exhaust clamps
Old 08-25-2015, 10:49 PM
MintWS6FORMULA's Avatar
Location: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
I have a Flowmaster muffler I'm thinking of putting on. I see it's made of heavier gauge steel for the inlets and outlets than the stock muffler. Will exhaust clamps work on it to crimp it down when the pipes are inserted into it, or will the connections have to be welded?
Old 08-26-2015, 07:02 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Weld or exhaust clamps
Should be able to clamp it just fine. If it leaks get it welded.
Old 08-26-2015, 07:20 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Coat the pipe with copper rtv and slip it in. Clamp hard it should crimp down and seal
Old 09-01-2015, 01:49 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Get the band style exhaust clamps that seal 360*, or get the torsen style and cut 4 slits in the muffler inlet/outlets and clamp it. As stated Copper RTV will usually hold up (below 750*F) and seal it. But could be hard to remove down the line.
Old 10-19-2015, 01:42 PM
Jackrabbit501's Avatar
Car: 1986 Camaro
Engine: 355 tpi
+1
Easy, cheap, and effective
Old 10-19-2015, 08:53 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Clamps to me are for making sure everything fits properly and for testing the sound.
I would clamp it without any kind of sealer and run it like that until you decide you like the muffler.
Then take it in and have it welded on.
The shop doing the welding will not be happy about there being sealer there.
manualbrakes.com
Brakes
63
04-09-2024 11:55 AM
92firebirdguy
09-01-2016 07:53 AM
Lanz06
09-14-2015 07:16 PM
ccop
Convertibles
09-14-2015 04:13 PM
Doobie52
09-11-2015 06:19 PM
Quick Reply: Weld or exhaust clamps
