Straight Pipe Questions
Old 09-10-2015, 07:08 PM
Camaro_383's Avatar
Car: 92 25th Anniversary RS
Engine: 5.0 TBI 305
I was thinking about making my 92 Camaro true duals by using a X-pipe and instead of running 2 catalytic converters, I was thinking about just not running any at all.
I've done some research and found out that our O2 sensors are not located on the catAly tic converter but on the driver side exhaust manifold. So since it isn't on the cat, would I have a check engine light by not using cats? Or even if I have to result with a Y-pipe would it have a check engine light? And if so how or what could I do to not have one if possible?
Thanks in advance!!
Old 09-10-2015, 11:49 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Straight Pipe Questions
You won't have a check engine light with no cats. OBD 1 doesn't monitor the cars like the newer OBD2 cars do. Even the newer cars only monitor the cat indirectly via 2 O2 sensors(one before and one after the cat). The ECM monitors the difference in O2 readings between the sensors to determine if the cat is "there" and/or "working". I've been running true duals with no cats for several years now with no CEL problems.
Old 09-11-2015, 07:22 AM
Camaro_383's Avatar
Engine: 5.0 TBI 305
Wow this is so exciting to me! Now I don't have to worry about having that in the back of my head when I do it. BTW are you running headers on yours as well? If so, what happens to that breather tube that goes down to the driver side exhaust manifold from the snorkle? I know I can just have an open element setup but I probably won't have it yet when I get headers
Old 09-11-2015, 09:05 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Yes, I have shorty-style headers. That breather tube is not needed. It just feeds the heat from the manifolds into the air intake for cold-weather starts. Since it's before the air cleaner, you can just remove it. If you plan on driving the car in the winter and it gets cold where you're at(like below freezing), you might want to hang into it just in case you have problems with hard starting this winter.
Old 09-11-2015, 11:28 PM
Camaro_383's Avatar
Engine: 5.0 TBI 305
Na I live in Texas where it's hot all year lol. But the coldest it may get in a year is around 20 degrees.
Well thanks my friend. You have been helpful in so many ways
Frozer!!!
01-19-2024 04:55 PM
Amillionoh7
05-24-2020 08:01 AM
87iroctheo
12-04-2016 11:47 AM
lt1z350
08-28-2015 05:57 AM
redmaroz
08-16-2015 11:40 PM
Quick Reply: Straight Pipe Questions
