Exhaust Advice
Car: 1992 25th Anniversary Camaro RS
Engine: 358
Transmission: 5 speed manual
Axle/Gears: 4.10
Exhaust Advice
I have a 92 Camaro with a 358sbc that came out of an old dirt track race car. I don't know a lot of the specifics of the motor besides that its a Stenhouse motor with a bullet cam that I put in it. Its probably somewhere around the 350-420 hp range (never had it on a dyno). I have 2.5 inch true duals exiting in front of the rear tires with 12 inch Cherry Bomb glass packs, no cats, and Hedman shorty headers. I was wanting to know if went to a single 3 inch exhaust dual 2.5 exit with a Magnaflow muffler such as the #16829 system would that be a good set up (in terms of tubing diameter)?
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Re: Exhaust Advice
Engine: 358
Axle/Gears: 4.10
Re: Exhaust Advice
So your thinking a 3.5" single with dual out would be better for me than the 3"
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
Re: Exhaust Advice
Dual outlet ends up taking a snaking path through the muffler. Single outlet performs better. Both work fine for what you are doing but just letting you know which is actually better performer. Appearance is the tie breaker depending the look you want for your car.
Engine: 358
Axle/Gears: 4.10
Re: Exhaust Advice
I defiantly want dual outlet. I'm just not a big fan of the single outlet. I was mainly wondering if I need 3" inlet with dual 2.5" outlet, or something larger such as a 3.5" inlet with a dual 3" outlet (or whatever inlet/outlet combo would be best)
Engine: 358
Axle/Gears: 4.10
Re: Exhaust Advice
If not i would prob guess yeah if your assuming MIN 350hp your gonna want atleast 3.5" single. You just need to start searching for exhaust systems of 3.5" single. From what i remember reading/finding is that most of the systems are single out. Now im sure you could figure some way out (or someone already has) to throw dual outs on it, it just might not be setup that way "out of the box".
Engine: 358
Axle/Gears: 4.10
Re: Exhaust Advice
Neither am i BUT do you really want Dual outlet for the look? Or do you just not want a single exhaust pipe showing? You could always have it dumped behind the rear bumper.
Thanks for your input by the way
Re: Exhaust Advice
I want it for the look. I like the way these cars look with the 3" and 3.5" chrome tailpipes coming out the rear. I was planning on buying a muffler with the appropriate inlet and outlets instead of a out of the box system, because I have an exhaust guy that fab up almost anything.
Yeah then your set! On this page http://www.hawksmotorsports.com/82-9...haust-systems/ are a couple examples of some 3.5" single systems. There are a couple there with 3.5" dual outs but they are quite expensive!
No prob, just passing on the information that was once told to me! Its a TGO thing
Re: Exhaust Advice
i'd go 3 1/2" back to a 4" inlet muffler with dual 3 1/2-4" outlet. i agree the muffler will be the bottleneck. you could also check the cfm rating of your muffler and compare it to the cfm rating of 3 1/2" straight pipe. but everytime you introduce bends or mufflers, your lowering the cfm rating. having the muffler as far back as possible is a good thing too, because the exhaust gases will flow better the cooler they are, (less heat expansion).
heres a generalized STRAIGHT pipe cfm to HP chart.
http://www.exhaustvideos.com/faq/how...98809814453125
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
Re: Exhaust Advice
If you friend can fab anything he can fab a system like the Borla, 1 going thru the muffler and 1 straight pipe with restrictor, you can even pick the sound level you want.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Exhaust Advice
The muffler is at the back of the car for one reason and one reason only... noise. Point the exhaust tips out the back for the least amount of interior noise. Hidden turn down exhaust is very cool but there will be more noise in the cab.
Re: Exhaust Advice
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Exhaust Advice
What you really want is a 3.5" pipe back to the muffler and a 3.5" tailpipe out. But any decent shop can fab up a "fake outlet" on the side of the muffler where there is no actual pipe. I know Mufflex does this for customers for the "look".
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Exhaust Advice
Don't waste your time any money over thinking this exhaust stuff.
Go with what is a proven setup. I have cars putting down 429/430 to the rear wheels with
a dual cat 2 1/2" into a 3" catback Magnaflow muffler with dual outlets.
Or a GMMG exhaust on a 355 motor.
Re: Exhaust Advice
Dyno Don really knows his stuff... I really wish i had a set of his headers/y-pipe.....
