Gutted Cross Member _ Swapping 1uz-fe Quad Cam Motor
Gents,
I'm currently swapping in a 1UZ-FE engine into my '92 GTA Trans Am, Now
Before you guys throw me over the bridge for fitting in a Lexus engine into a Pontiac Trans Am, I've a bigger issue than being wet by river water.
The thing is, the mechanich had cut almost 50% of the corss member (withour my permission), to make enough room for the oil sump of the 1UZ-FE engine, now how bad is that??
Is there any way of fixing this issue, cause am a little worried about the chassis strength now?
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Gutted Cross Member.
one interesting swap, look forward to some pictures.
depending on how its been gutted, you'd want to weld in some plates to keep rigidity; the LSx guys are pretty used to having to notch things and reinforce them to keep the strength
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
box it with 1/8" plate, or buy a tubular kmember for the nicest looking install
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
this sounds interesting, you need to post pics.
as for the k-member, box it back in and you should be fine. If you feel the need, there is enough room in the front of the k-member between it and the steering linkage to add some gusseting if you feel the need.
Also, not gonna spring for the 1LR-GUE? lol.
Re: Gutted Cross Member _ Swapping 1uz-fe Quad Cam Motor
The reason I've decided to go for 1uz-fe engine, due to it's reliability, and trouble free. It's also has a brilliant Quad Cam design, and my specific motor has Variable Valve Timing. It's an aluminium engine, so not as heavy as SBC. It produces 290hp on motor, that's 73 hp/liter, whereas the SBC has 43 hp/liter. Even LS1 engines could not match the 1uz-fe in the hp/liter figure in stock form. I mean the 325hp stock LS1 has 57 hp/liter vs 73 hp/liter for the 1uz/ fe. The only downside is it's small capacity, mine is 4.0 liter, however, had been there a 5.7ltr stroker of the 1uz-fe, it would have been a game changer, pumping around 420hp at any given time. The other downside is the lack of aftermarket support, and here where LS1 and SBC shines
Car: 86 Camaro Z28
Engine: LT1 200cc Ai heads and cam
Axle/Gears: 4.10:1 Zexel Torsen
they chopped the hell out of that cross member. I would brace it some how.
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
You really need to get a picture from looking up with the engine sitting in the cross member... if you want more input or improvement on your current cross member design and structure...
Car: '91 TA vert
Engine: turboLSx
Keep us posted, I would love to see this completed. How much room do you have between the current kmember and oilpan? A tubular may not even work for you. A better option may have been a custom oilpan/pickup setup... The oilpan is aluminum, right?
Edit; Or another option may be to build a cradle with front and rear crossbars if you have clearance underneath the bellhousing?
I don't like the idea of removing metal off a main beam like the cross memeber, however, since the damage has already happened, I favor Kid's idea, in welding a piece of pipe in it, or 2 parallel pipes, and I hope that should do, but man, I wish if I could have avoided this altogether. I think once I fire the UZ motor, then I would be able to tell if it was well worth it, or is a complete fail.
Car: 86 Camaro Z28
there is always room for a turbo if it isn't fast enough
Well, I've always wanted it to be as civilized as possible, a daily driver to work, with a alittle twist of grunt and torque, I think it would be able to keep up with a stock 2006 Mustang GT, but no chance with an LS1 4th Gen F-body
go with the K member replacement, I did it when I swap my 350 for a LS-1, it lightens up the front end and makes it feel like its on rails....or stay with the butcher job and slap on some plates and hope for the best! MHO.
Car: 86 Camaro Z28
https://www.thirdgen.org/forums/engi...y-k-frame.html this was in the for sale section. I'm not sure on the ground clearance
Don't think it was ever finished, threads 4 years old with no further updates
NBrehm
08-05-2015 07:57 PM
