Tuned Port Injection - 30 years old
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
October is customarily new car introduction month, that would make TPI 30 years old. The year 1985 was in the heart of my formative automotive years. I was just learning how to rebuild Quadrajets, and I remember the indroduction of TPI as some mystrerious new space aged induction method. Back in 1985, the small block Chevy was 30 years old. At the time, it seemed that 1955 was a much farther back in history that 1985 seems to be now.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Tuned Port Injection - 30 years old
I look at that picture of the TPI, and it strikes me.
1) the exhaust is coming out of the side, like it would be in a FWD vehicle.
2) The transmission or whatever hanging on the back looks like a FWD version, or something else for testing, not really sure. It appears to be an automatic of some sort with the servo on the side, but it does not appear to be 700R4 or 4L60 (might need help identifying this thing)
3) the Engine is missing all of its stickers, like the one on the Harrison A/C unit and the alternator.
4) It is an 88-92 serpentine setup...
Cool pic tho, thanks for sharing.
Really when you break down a TPI system they are simple in comparison to some of the new engines out there...
I am not sure if we have gone as far as we did from 1955-1985 from 1985-2015, as it seems there were greater leaps in technology between 1955-1985. WE seem to be rehashing old things and making what we know better.
I think many people do not realize that the port fuel injection in a production vehicle goes back to 1976, Cadillac had an engine that had injectors on every cyl. As did Nissan (the Datsun 280Z in 1976 had a straight 6 with 6 injectors.)
John
John
Having owned and restored a 1956 Corvette including rebuilding the entire engine by myself (although I had an expert rebuild the carb to NCRS standards), I would take a TPI engine over it anyday! Setting the carb using a vacuum gauge or setting dual points with a dwell meter is like black magic compared to TPI with it's sensors I can clearly see and control with a laptop and a cable.
If both a carb and a TPI was in good working order, I think in so many ways the TPI is more drivable too, throttle response is faster, just overall better for a street car. There is no comparison IMHO...
Granted, my 87 Formula with the LG4 was one of the best carb cars I have ever owned. Mash the throttle twice, and it would fire up like a FI car... But I have not looked back either...
John
John
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
88 was different, that is 89-92 belt routing.
I have heard this, but not sure of the differences. They appeared to be basically the same tho, not sure how to tell the difference...
John
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Left exhaust DOES actually run slightly forward as it transverses under the engine, in FRONT of the oil pan sump.
The serpentine belt routing was changed in a TSB to run from the WP to the crank, and then to the AP in attempt to quiet down that noisy R4 AC compressor.
The problem with the transmission in the picture is that for some reason, it has the tailstock removed.
We don't see the other side of the engine, likely sectioned out to expose the pistons and such.
Fast355
12-02-2016 06:33 PM
toronto formula
11-10-2015 06:17 AM
