remove firebird shift knob?
Old 09-04-2010, 01:24 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
remove firebird shift ****?
hey i'm trying to replace my shift plate in my 89 GTA and i just need to remove the shifter **** and it'll be off. how do i do that?
Old 09-04-2010, 01:49 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: remove firebird shift ****?
i now this from experience, in the front of the stem of the shifter there a notch where a staple looking keeper comes out of, if you pull that out then the shifter head should just pop right off, if not, dont force it or it will break
Old 09-04-2010, 10:13 PM
Engine: 350 L98/LS2
ok well i got that pin pulled out, and the **** isn't budging. do i need to do anything else?
Old 09-05-2010, 08:28 AM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
well when i got a new one at the junkyard it just pulled off for me, my other one broke cause my frined decicded to twist it off with the pin still in, but thats wierd
Old 09-06-2010, 11:20 PM
Engine: 350 L98/LS2
it came off eventually. i just had to pull and pull, and pry it off with a flat head screw driver. came right off then.
Old 09-07-2010, 02:33 PM
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
good glad to hear you got it off, i thought it may just be a little tight
Old 08-23-2017, 11:55 AM
rgauder's Avatar
Car: 1987 Trans Am
How about getting the damn thing back on?
Old 08-23-2017, 03:10 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I usually hit them with a hammer.
Old 08-23-2017, 04:46 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I'd recommend a rubber mallet instead if you have one.
1992 Trans Am
05-10-2023 07:19 PM
OLDYELLR
Car Audio
09-30-2015 07:10 PM
dhonda200
08-11-2015 11:50 PM
3rdgenparts
08-08-2015 07:09 PM
drathaar907
08-06-2015 04:20 PM
Quick Reply: remove firebird shift knob?
