Roof console noise...anyone?
Old 07-29-2011, 01:28 PM
camaro87jb's Avatar
Car: 87 Iroc z
Transmission: AT
Ok stupid post i admit it but... its driving me nuts....
Recently had my old headliner re done. The guy used the newer ABS type one for a t-top car. Looks great, however now the overhead console seems to make alot of queeks and nosies on bumpy roads. anyone else have this issue? I was thinking about removing the console to see if i could see anything but worried I might break it.
Old 07-29-2011, 07:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Roof console noise...anyone?
Overhead console removal is easy - remove cabin light cover, use needlenose pliers and remove the two pushnuts off the studs inside the light box. Then, the console simply slides back about 1 inch, and drops down. Sounds like the ABS is not thick enough - stuff some old T-shirt pieces between console and headliner, and slide it back into place.
Old 07-29-2011, 09:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
With the T-top version, you'll slide the console forward toward the windshield. With the coupe version, you'll slide the console rearward toward the hatch.
The coupe version, BTW, has a cardboard and foam reinforcement that goes between the headliner and roof.
JamesC
Lbibb
05-05-2016 12:00 AM
LC2 TECH
10-13-2015 11:53 PM
FormulaEngland
09-30-2015 01:50 PM
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
ndndndnd
09-28-2015 08:00 AM
Quick Reply: Roof console noise...anyone?
