How remove dome light assembly?
Old 08-27-2013, 05:00 PM
Chuck's Avatar
How do you remove the dome light assembly
in an '89 RS?
Thanks!
Old 08-27-2013, 07:13 PM
mdwallace's Avatar
Car: 1992 Camaro
Engine: Ls1
Axle/Gears: Currie 9" 4.30
Re: How remove dome light assembly?
about 6:30 into it. Hope that helps
Old 08-27-2013, 07:17 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
in an '89 RS?
Thanks!
Remove light cover,then remove the light, then remove the two "clips on each of the roof studs. Light should be loose at this point.
Bare roof with light and headliner removed
Old 08-28-2013, 11:00 AM
On Probation
sonjaab's Avatar
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
Those "pins" holding the bulb assembly to the roof just unscrew
with the help of vicegrips or pliers.
They are threaded on the other end..............
Old 08-29-2013, 10:00 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
My TTop car had rivets and I cut them out with a grinder, then I put it all back with screws which work well.
Vintageracer
01-10-2020 05:33 PM
1992CamaroGirl
12-25-2017 08:45 PM
Omega
08-10-2015 12:46 PM
3rdgenparts
08-08-2015 07:09 PM
Quick Reply: How remove dome light assembly?
