Power mirrors
Old 01-25-2015, 11:08 PM
AC/DC Freak's Avatar
Car: 1986 Camaro I-Roc Z/28
Engine: 5.0 305 TPI V8
Transmission: Automatic
Power mirrors
I have a 1986 I-Roc Z/28 with the power mirror option, the only problem is neither mirror works and i am wondering is there a motor that needs to be replaced somewhere or do i have to get new mirrors altogether?
If it is just replacing a motor or something where is a good place to find that?
Thanks.
Old 01-26-2015, 08:41 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Power mirrors
Both mirrors, I would suspect the switch itself.give it a test.
Old 01-26-2015, 11:48 PM
Re: Power mirrors
So if the switches are good, i would need to replace both mirrors?
Old 01-27-2015, 06:12 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Power mirrors
It's not likely both motors would fail at the same time. Also, the effort & cost of replacing them might be more involved vs. troubleshooting the switch and wiring. Other than checking the fuse, you would need a multi-meter to find out if the switch is getting power and if the power is going out to the motors.
Old 01-27-2015, 06:24 AM
Ta Re Ser's Avatar
Car: 88 GTA Ta
Engine: 5.7 TPI
Re: Power mirrors
I had the same problem on my 88 TA. It was the switch, the switch gets exposed to a lot of abuse over the years which the power motors rarely get.
Old 01-28-2015, 06:43 PM
Re: Power mirrors
Ok that makes sense it is probably the switches,but just out of curiosity, there are actual motors that power the mirrors how do you replace them? Do you need to buy new mirrors or new motors?
Old 01-28-2015, 06:57 PM
Ta Re Ser's Avatar
Car: 88 GTA Ta
Engine: 5.7 TPI
Re: Power mirrors
Couldn't answer that one. Sorry I'm sure if you search somebody has done it
jaridjohn
04-25-2019 03:21 PM
ziggy89
Exterior Parts Wanted
09-10-2015 08:44 AM
Slush92RS
09-02-2015 08:56 PM
z28guy134
09-01-2015 11:50 PM
SlowAZ28
Members Camaros
08-31-2015 07:53 PM
Quick Reply: Power mirrors
