Upper console fixing
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
Hi all!!
fast question: how is the upper console supposed to be fixed in the frontal part to the chassis? I've found no way apart from manually modifying it.
THANKS!!!!
THANKS!!!!
Transmission: Pro-built 700R4
Re: Upper console fixing
Are you talking about the overhead console? If so, there are specific screws that go up there that the console slides on to.
Engine: 5700cc
BTW, are you talking about these in particular?
f213a7c0.jpg?t=1342825765
bye
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Your console is either very different from us models, not from a third gen, or heavily modified. Doesn't look anything like one I've seen before. Keep in mind that ttop consoles are different from hard top consoles.
No, that is a third gen console. It just has all of the stuff removed from it. No map pocket, dials, map light or buttons.
Ah, I thought itt had stuff on top if it, now I see we are looking through the openings to the roof.
What are you working on putting in that spot. I've been toying with the idea of relocating my window switches to that area.
Engine: 5700cc
It provides me 1) clock 2) in temp 3) out temp
I'm removing the light to put a panel with 2-3 red LEDs for interior low red glare, very common in modern cars.
Removing the pocket too to put: bluetooth mic, pioneer auto equalizer mic, USB port and aux-in (not sure about those positions), second fan switch, and a switch to control another very low red glare at foots.
The upper console is the only thing I modified in the car. Everything else I keps original.
Car: 85' TA, 99' 30th TA, 09 G8 GTX
Engine: 305HO L69, 350 LS1, 6.0L L76
Transmission: T5, Hurst 6, 6L80E
Sounds like a nice project. I look forward to seeing updated pictures.
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
subbed, i have a spare console that nobody seems to want to buy, i may follow suit and mod it to be more useful in today's world
Engine: L03, LB9
yeah i definitely thought they would be more desirable, i have a hard top and t-top console up for grabs but it seems the only people that want them just want parts because they already have the console.
oh well. OP i hope you keep us updated on your progress with this, would be very interesting to see the steps you take with modifying this piece.
Car: Used to be an '87 IROC
Engine: 5.7l TPI
Axle/Gears: 3:23?
I took the "wheely reminder thingy" out of mine and made a block plate to fit the hole. I mounted a pushbutton that activates my garage door opener. The guts of the opener are back in the rear portion of the console. I had a friend make me a voltage regulator that drops the voltage to 9V for the opener.
1 Post
Car: 1989 GTA
Engine: LS coming soon
Transmission: 80E coming soon
Axle/Gears: S60/35 Spline/S-Trac/3.73
Anyone else mount anything cool in that spot?
I'm very interested in replacing those useless dials!
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I gutted mine and put an old digital clock in there behind some smoked plexi that only shows when you push the map light button. Who uses the oil change **** thing anyways? haha
