For sale: LS1 fbody clam shell motor mounts
Engine: Cammed 6.0L LSX
Since I swapped a pair of poly mounts onto my car tonight I'm gonna sell the ones I removed. There's nothing wrong with them, it's just that because of the big cam in my motor the exhaust was hitting the floor and I wanted to try and get rid of that. These would be great for someone going for a mild build without a lopey cam.
I painted them black right before I put them on my car, which was about 1,000 miles ago.
$40 shipped.
$40 shipped.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: For sale: LS1 fbody clam shell motor mounts
So, this is the actual steel mount and not just the insert that mounts to the engine? If that is what you mean I am interested
Blue,
Did you have a spare set of clamshells that you swapped the poly mounts into, or did you find a place that sells them complete? I just picked up a set of OEM rubber clamshells under the assumption that I need the steel shell to put the new poly mounts into. I'm just second-guessing if my assumption was correct.
Jim, I bought my new mounts with the poly bushings already installed. So yea I actually have two sets, these and the new ones. I figured it would be more convenient to buy some complete ones instead of taking mine off the car and taking them apart to put in the bushings before I installed them.
Sorry I should have clarified. These were used clamshells with new bushings. I don't know of anyone that sells them assembled brand new.
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Transmission: TH-FO-HUNNIT
Are these complete clamshell and bushings? And still for sale?
ambainb
04-25-2016 09:21 PM
NBrehm
08-05-2015 07:57 PM
