Running a cracked block
Old 09-21-2010, 12:26 PM
On Probation
Atilla the Fun's Avatar
Engine: several
Transmission: none
Axle/Gears: none
I've decided to re-assemble this and run it, see what it'll survive. First, a pic of the location of the pin-hole crack, which I put white-out on:
Old 09-21-2010, 12:27 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Running a cracked block
And here's a pic of how I found the crack:
Old 09-21-2010, 01:42 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Consider it extra oiling for the cam
Kind of a strange place for a crack
Old 09-21-2010, 02:32 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
This is what happens with blind holes when you tighten the bolt, not realizing there's oil or water already in there. The results are usually far worse than this, especially with aluminum blocks. I've seen an aluminum LS1 block split wide open. That was from the second-to-rear, outer row head bolt on the driver side.
Still, I'm gonna clean it, machine it, re-clean it, JBWeld it, and then assemble it.
My testing procedure requires good hearing, this one didn't sound much different from the others. I wasn't sure, so I took a break, then came back to it. I had my pressure regulator set to exactly 100 psi. Be sure to do your listening when your compressor isn't running.
Frozer!!!
01-19-2024 04:55 PM
Jake_92RS
01-28-2020 10:37 PM
evilstuie
01-09-2020 08:29 PM
Infested
05-22-2018 11:56 PM
theshackle
03-05-2017 06:37 PM
Quick Reply: Running a cracked block
