anyone making LT1 swap harness
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
I have the lt1 dropped in my trans am and one of the things need done it that wiring. 86 carb to 95 lt1. harness is out of a 95 caprice. I am trying to determine whether i should just attempt to wire the car up myself or whether it would be easier to buy a swap harness that has been cut down to stand alone, have a custom one made to plug and play, or have my harness reworked by someone else. So what are my options?
Re: anyone making LT1 swap harness
Anyone else make the harness, I want a bare bones one, that keeps ac and accessories running like stock, just no ecm. The engine was a 350 TBI, now it's a 355 with 4bbl Edelbrock.
The same member that I referred to in post #2. Pocket. He can make one how ever you need. He's the OP of the other thread you posted in. Although to be fair, what you're for wiring harness is not hard to do, read the other threads Pocket has started on harnesses.
Car: 1986 camaro iroc
Engine: About to do a lt1 swap on it
Transmission: 4l60e
Pocket, I'm a new member and I'm about to do a lt1 swap. I have a 86 camaro iroc and I'm using a lt1 engine out of a 95 camaro z28. I have the wiring harness, ecm ect. I'm using the transmission out of the 95 camaro z28 as well. Are you still making plug and play wiring harness for this swap. I'm planning on keeping a/c. Any help would be appreciated. Thank you
Transmission: 4l60e
Are you still making lt1 swap harness? I'm about to do a lt1 swap with a 1986 camaro iroc 305tpi and a 1995 camaro z28( I have wiring harness ecm ect) also using the transmission that came with the 95 z28 as well) do you make them so they are pretty much plug and play? Any info will help. Thank you so much
Transmission: 4l60e
Transmission: 4l60e
Do you happen to have his email?I cannot find it on his contact info. Thank you for responding, I really appreciate it.
Car: 92 Firebird
Engine: Supercharged 6.0
Axle/Gears: 8.8 3.73
To email a member click their screen name and select email from the dropdown
PM sent
PM sent
Transmission: 4l60e
Ive been trying to get a hold of you. Hopfully this messge will get to you. I sent a email as well. I would like you to make a lt1 swap harness for me please. I have a 86 iroc, dropping in a 95 z28 LT1
I would like to get started on it as soon as we can. Thank you
Car: 85 Z28
Engine: 93 LT1
Axle/Gears: 3.73 01 SS
If anyone is doing this themselves I could help answer questions about the wiring. I can also help with tuning 94-95 lt1 ecm.
1992 Trans Am
08-08-2015 08:16 PM
