Project White Devil (1991 Z28)
Hey folks. Figured I would start a build thread for a new thirdgen I just picked up. Some of you may have been reading the thread I started in the classifieds feedback section pertaining to the sale transaction with this car but for those that havent, you can click this link to get an idea of what I went through with this car within the first 3 days of taking possession of it.
https://www.thirdgen.org/forums/clas...xperience.html
Now that that is out of the way lets get started with this build thread. I have been searching for a 91-92 white hardtop Z28 for a LONG time and finally got one. Its not perfect but it will be a work in progress. The car has 58K miles on it with a 350TPI/A4 combo. It is 99% loaded with all the factory options. I think the only thing it doesnt have is the factory CD player.
These are pics from the previous owner
Plans for this car will be:
Weld S71 wheels with Nitto tires 17x8 and 17x9.5
White face gauges.
Eibach lowering springs( Pro Kit)
Founders Performance LCAs and adjustable track bar
Founders Performance fabricated strut mounts
Founders Performance LCA relocation brackets
UMI steering brace
member Formula1LEs HD power window harness
C6 51 front brake kit with Baer brakes from bigbrakeupgrade.com
drum to 13" rear disc conversion with new OEM 1LE brakes and Baer rotors
tinted windows 20%
full exhaust (havent figured out what I want yet)
smoked turn signal and marker lens' up front
HUMount radio installation trim kit
90% of those parts are already sitting on my bench. I have to do some unexpected repairs before I go mess with upgrades.
windshield needs to be replaced as well as the hatch motor and heater core.
Stay tuned for a LOT more pics and updates.
White face gauges.
UMI steering brace
tinted windows 20%
Axle/Gears: 10 Bolt 2.73 Open
Re: Project White Devil (1991 Z28)
Looks a lot like my '91 RS...Arctic White, white 16" wheels...very handsome.
Sorry to read about all the surprises when you bought it.
Few more mods I did last night. Smoked marker and turn signal lens' OEM ones were cloudy and had moisture in them. These look a lot better during the day outside against the white paint.
I also HAD to repaint the blister inserts since 99% of the black paint was missing and it was bothering me. I'm willing to bet that the paint came off when Maaco pulled the masking tape off of them. This is just temporary since I don't care for how they turned out (spray paint I had sitting around in the cold garage). I plan on replacing the inserts with something else at a later date. Its not perfect but 1000 times better than what they first looked like.
I had a chance to rebuild the hatch motor today using parts from TDS. Everything went well for most part but I need new hatch struts and a new battery so I cant sign off on this repair until both of those things are replaced. Battery is at 20% now so he hatch motor is slow.
Notice the yellowish goo around the motor housing... It is epoxy that helps to reinforce the plastic housing.
hatch motor parts come from http://www.top-downsolutions.com/
Also got some new parts in today!! Weld RTS wheels and C6 brakes.
brakes come from www.bigbrakeupgrade.com I HIGHLY recommend using Scott for yor brake needs. He went above and beyond to help me figure out what would be best for me.
If you haven't put the tires on those wheels yet you should really consider doing a 9.5" wheel up front. Will you be keeping the engine and transmission original? It took me a while to find my white convertible, too. It's also a 91 Z.
I went with the 8" wide wheel up front for a few reasons. First, I didnt want a deeper lip on the front wheels versus the rears. Second, I dont want to run spacers. Third, I dont drive the car enough to justify the more expensive tire and wheel up front. Plus, the roads in New England suck and I have had a lot of cars with wide front wheels and the cars just track in all the ruts.
Another reason was the lack of a high pad design WITH an offset that would work for me. Weld, just didnt have it so I went with the 17x8 in a high pad design to clear the C6 Z51 brakes.
As of right now, the drivetrain will remain stock unless a disc rear with 3.73s falls into my lap.
I had a chance to get a few more things done on the car this weekend.
I also put a brand new Spectra heater core in which was about the biggest PITA job I have done in a while! Once that job was done and I was confident I had no leaks, I parked the car in the garage for the beginning of a few big upgrades!!! Car is jacked up and ready to be wrenched on.
Transmission pan was dropped to replace the filter as well as whatever fluid was lost in the process. I used AcDelco Dextron IV fluid along with an AcDelco filter and Felpro gasket.
Next up was rear suspension upgrades. I put new Founders Performance LCAs and track bar in along with Konis and Eibach springs. I was on the fence about using the stock isolators and decided to just reuse them Hopefully the stance is right when the job is done.
Quick side note here... I bought the Founders Performance LCA relocation brackets and they didn't fit at all!!!! Not too happy about that since I now have to fight with them on Monday about what they're going to do about it. I may just buy the UMI bolt in ones.
Too bad you've had to go through all those issues with the purchase. The car has a lot of potential though, those Weld rts wheels will look great and totally change the look of the car. Subscribed, looking forward to watching you fix it up.
Well it looks like I will be needing a starter since the OEM one is making terrible noises. Im looking at possibly picking this one up from Summit.
http://www.summitracing.com/parts/SUM-829100
Summit's stuff is either going to be rebranded name brand or chinese. The reviews make it sound like it is chinese with some having good results and others think it's junk. Common for chinese parts to have poor QA. I have had a power master for ten years now, turning over engines between 9.5-11:1. I recommend that brand.
Ya I looked into it further and decided that I wanted a starter from a local store. I picked up a starter for a 95 Corvette. Cost me $85 after rebates and a core return. Lifetime warranty. We will see how it goes.
It's supposed to be a high torque mini starter. Ain't going to matter now though because it doesn't fit. The solenoid is up against the oil pan and the wiring isn't long enough to to reach the lugs.
I bought this based off of what other members' we're using. Not sure what the deal is at this point though. I'll post pics in a bit.
I do have an old Autozone Duralast starter for a 305 car that has a lifetime warranty that I could always fall back on but I'd like to use something a bit better if you know what I mean.
So its back to the Advance Auto parts tomorrow to return this starter and then take a drive to Autozone to swap this old Duralast starter I had from my last car.
Notice the size difference between the 350 starter and 305 starter... I'll just have to settle for the 305 starter since its free unless I find something worth using tonight on the internet.
Slight setback today. I bought a brand new Optima Red Top battery from the local auto parts store last week and it will not hold a charge over 24 hours. Battery has been disconnected for 2 days while I have been doing a corvette starter mod and the battery was at 35% this morning. Build date on the battery is 5/15. I can only assume that its been sitting on the shelf for 10 month discharging. Time to figure out what my next battery will be.
COTM Editor
Congrats on the new project man! I hated my red top. I had to exchange it every year under warranty.
Car: 92 camaro rs
Engine: 305 t.b.i.
Hi,
awesome looking car so far. May I ask what size tires you plan on using on the weld rims? Did you have to modify anything in the wheel wells?
Mark
Mark
I'll follow your build. I almost bought the twin to this car when I was looking at thirdgens. Only difference between the car I looked at and yours was the car I considered buying had a cloth interior. I'm glad your working on it and keeping it on the road!
Car: 92 camaro rs
Engine: 305 t.b.i.
Thanks. Cant wait to see pics of the wheels and tires on the car. Sorry forgot to ask what back spacing did you get for the wheels?
Mark
Mark
1 Post
Car: 1991 Camaro Z28
Transmission: 5 speed
Axle/Gears: alunimum drum limited slip 3.08
I thought I saw a SLP TOTL exhaust in the background in one of the pictures above. What about using that exhaust?
Because as good as it may sound, it looks goofy from behind the car and I just cant deal with two pipes on the left side of the car. I just bought the Magnaflow cat back for $473. Not bad considering its $590 everywhere else.
1 Post
I had the TOTL installed last year, I'm still getting use to the 2 pipes on the one side. Yeah that is a good price on the Magnaflow. Are you thinking of selling the TOTL?
Nice, I need a source for those new turn signal lenses.
eBay
Fingers crossed it comes in and it's complete. Itnwas literally $100 cheaper than any other vendor out there. I'm ditching the tailpipes and going with the B&B quad tips I have now. I can't stand big 3" 1990s chrome/polished tips.
#43
I'd like to find a way to run a factory-style tail pipe with their system.
#44
I had a B&B Tri Flo catback from a 4th gen on my last car (1991 Z) and I loved the tips. The muffler was invaded by mice when I had it in storage so in the trash it went. I saved the tips and will try to use them with the Magnaflow. I will most likely have to buy two new tailpipes to get them to work. I dont want to cut up the Magnaflow ones. I may be able to sell them to someone and make some of my money back.
#46
Ive put 4 miles on this car since taking delivery of it and this is the pile of parts I have already removed from it. Some of these parts needed to be replaced while others were a want more than a need. Either way, the car should drive and perform a LOT better now as well as be a lot more reliable.
#47
Car: 92 camaro rs
Engine: 305 t.b.i.
Hi.
Can you please tell me what backspacing you used for the wheels? Looking for wheels for my 92.
Mark
Mark
#50
here is yet another update on the car. I had a chance to install the Magnaflow catback system on the car over the last couple days. I had intentions of saving what I thought was the OEM exhaust but found out it had been replaced at some point with total junk. Whoever did the install needs to quit working on cars because they suck. Over the axle pipe (2.5" dia.) was smashed in with a hammer to gain clearance. Not sure why someone felt the need to smash a 2.5" pipe when I was able to fit a 3" pipe up there without any problem.
Anyway, old system was cut out and tossed in the scrap pile. I needed to make my own 3" adapter pipe to get the system to bolt up to the ypipe. Basically just used a 16" length of S.S. tubing and slipped it over what was coming off the ypipe.
I also wanted to use the B&B tips I had lying around from my last car. The tailpipes/tips that come with the Magnaflow kit look like crap and its not 1995 anymore. In order to use the B&B tips, I had to buy a pair of Walker tailpipes from Summit. A couple cuts and a trip to the muffler shop to have the ends expanded and on they went.
Here is a few pics of the system mocked up to the car for now.
