Mid-West Region Regional message board for WI, IL, IA, MI, MO, and MN to organize gatherings, meetings, and to help each other out.
305 TPI, Holset H1C 3800 SC injectors
Old 04-16-2007, 06:35 PM
Drac0nic's Avatar
OK, it's looking like my trans took a **** for good so I'm looking at alternate modes of transportation. This means building a war chest up to find a new vehicle. All stuff located in Carbondale, Illinois
This includes:
305 TPI engine
1986 motor, 1 piece rear main seal TPI intake without cold start injector
-30#/hr stock Grand National injectors installed (have 2 sets will include extras)
-Competition Products Z28 springs
-Summit K1103 cam 204/214@.05, .42/.442 lift
-ported stock heads and intake, stock valve covers PS pump, 2 alternators one tested other not
-Hedman 68600 headers, these are for an Astro/Safari swap as well as G-bodies, El-Caminos and second generation camaros among others.
-Cloyes OEM sytle timing chain
looking for $500 out of it, have a good bit more invested.
-One set V8 Astro swap motor mounts, clearanced for 68600s, $50 shipped
-H1C Holset turbocharger, 48mm compressor 16 CM^2 Turbine. I checked the clearance end to end with a dial indicator, it's within spec even though the compressor rubs slightly. I think it's because the oil pad it out. Would like to see 100 shipped.
-set of 28.5LB/HR injectors for a 3800 V6. These are the standard Bosch style injectors, would be good for someone wanting to start out on a N/A V6 with boost.
Will also consider trading for a good running daily and some cash.
69 Six Pack
10-05-2015 07:51 PM
gta90
09-15-2015 04:00 PM
Brcharrelson
08-26-2015 07:47 PM
st.evel07
08-13-2015 06:15 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: 305 TPI, Holset H1C 3800 SC injectors
