Rear mount turbo. Tpi
Old 03-31-2015, 09:52 PM
MY87T/A's Avatar
Car: 85 IROC "SYNASTR-Z"
Engine: 355 SBC
Transmission: 700-r4
Axle/Gears: 3:73 disc brake
So Im currently building an 82 z28 into a turbo tpi car. I have a l98 tpi long lock in the car with carbed intake. I also have a 89 I believe tpi without cold start etc. I'll be using megasquirt to run it. I'm going remote mount because I already have the parts. I'm removing all the oil system. Pump turbo. Etc from my 01 Silverado 5.3 that I had rear mount turboed. It's a fun truck but the weight makes it a little slow. I've seen pictures before of this done to a third gen. Just looking for more. Or advice if you've done it. I have everything basically planned out aside from the charge pipe routing and the actual turbo mounting. Considering the major opening under the passenger rear muffler spot. I may turn it sideways and run open downpipe straight out. Just gathering ideas.
Old 04-01-2015, 12:54 AM
Night rider327's Avatar
Car: 1988 Camaro
Re: Rear mount turbo. Tpi
Do it kinda like the STS systems for the 4th gen F bodies.
Old 04-01-2015, 07:04 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Working on one myself for my blue z28. Its on back burner as i finish up some upgrades to my black iroc first
Old 04-01-2015, 09:13 AM
MY87T/A's Avatar
Engine: 355 SBC
The fourth gen has slightly more room under it and also due to the body. It doesn't sit as low back there. My car already is lowered and need to keep my chances low of something hitting it. I wanna see actual third gen pics because I KNOW people have done it. Lol
Old 04-01-2015, 09:28 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I am putting a 4th gen gas tank and rear in car currently. Mine is a 305 tpi car all stock. Running new replacement 2.25" exhaust to rear and putting an On3 T70 there. Looking for 330-350 whp if i can.
Eventually want to rebuild motor, mild cam, refresh heads maybe vortecs, and some kind of intake either hsr or single plane efi like i have in my other car. Or ported tpi with slp runner if i canfind some under 300$. We'll see
Something like this
Old 04-01-2015, 01:24 PM
MY87T/A's Avatar
Engine: 355 SBC
Not to bad looking.
Old 04-01-2015, 02:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I was planning on coming out of compressor into an intercooler mounted under trunk next to turbo and then running down driver side. But now i may look at a cooler up in the nose of the car. We shall see. It will be hot air low boost setup initially
Old 04-01-2015, 03:33 PM
MY87T/A's Avatar
Engine: 355 SBC
Mine is gonna run no more than 5psi on a good day till I finish the 383 bottom end. Then I'll be running 15 psi with watermeth injection and possibly e85. Until then I gotta get the turbo plumbed and what not
Old 04-03-2015, 09:31 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I was thinking the same thing with the A2A IC in the rear on a planned 4th gen car. Sort of going back and fourth with the A2A or just going A2W IC in the rear. You running the check valve in the inlet oil line or doing the outlet sump? I plan on doing a small sump with no check valves at all using 1/4" feed line and 3/8" return line from the oil pump.
Old 04-04-2015, 10:21 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
I've got a couple of pics on my desktop of a guy in Edmonton that did a RMT on his Camaro.
He cut and raised his trunk well which gave him lots of room.
Ran 11's on a carbed setup if I remember correctly...
I'll post pics of it later
Old 04-04-2015, 12:55 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Here we go gents...
Old 04-04-2015, 01:13 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
and a few more...
I've thought about this forever now... Boosting that is...
The Original poster said he was gonna run MegaSquirt but...
Can you run a 165 ECM 6E MAF mask or do you gotta switch to 749 ECM $58
I'm a little scared to switch over
Not Hijacking just confirming for the rest of us
Attached Thumbnails Rear mount turbo. Tpi-james-blue-rmt-under   Rear mount turbo. Tpi-james-blue-rmt-trunk   Rear mount turbo. Tpi-james-blue-rmt-turbo
Old 04-04-2015, 10:21 PM
MY87T/A's Avatar
Engine: 355 SBC
I'm not a fan of factory computers. I like standalone setups. Seeing as I feel it's a little easier. I've tuned my truck with hptuners. And really wish Ida went standalone. There's so much factory crap to do away with. I spent more time tweaking that then actual tables.
Old 04-07-2015, 07:06 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
No sure what you mean. I wasnt doin anything special at all. Just -4 feed and -6 to -8 return depending. Ofcourse if i could do it with non braided line for cheaper i would but i have -4 feed already.
Old 04-07-2015, 02:12 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Without check valves, the oil feed will drain into the turbo when the engine is off. The drain may do the same depending on the location.
Check valves can stop this from occurring, or a small sump can be installed on the return side under the turbo to catch the fluid from the lines instead of overflowing the center section and leaking into the compressor and turbine.
Old 04-07-2015, 02:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Hmm. Havent heard of that before. Never had an issue on my twins and it doesnt have check valves or sump but they do drain vertically for a few inches. I'll have to look into that
Old 04-07-2015, 02:25 PM
MY87T/A's Avatar
Engine: 355 SBC
Mine doesn't do that either and I have a 90 at the bottom of the turbo. So there's no where for the oil to drain without the pump. And I've yet to see it build up and leak. I've put 1000s of miles on it so far. I'm getting other things sorted before I get this turbo on. Gotta finish up a few other things first.
Old 04-07-2015, 02:28 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I guess you could add a timer function to keep pump running after shutoff. I like the ls1 pcm for this, it allows fans to run temporarily. Could tie into that circuit for scavenge pump but i wont be doing another 24x setup
Old 04-07-2015, 02:37 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Your front mounts have drain line under them before the pump. That is your reservoir. Short distances are fine.
amount of oil in a line = ((LINE_ID/2)^2)*3.14 * LINE_LENGTH * 16.38 mL.
Suppose rear mount with 4/16" line with 3/16" ID that is 15 feet to turbo. That is 6.7mL. Not much, but if the remote pump is higher than the turbo then that line is back draining toward the turbo too.
Old 04-07-2015, 02:42 PM
junkcltr's Avatar
Engine: 3xx ci tubo
I don't like running fans, timers, etc after engine is off. I was going to do the turbo timer thing with the PCM I have until I did the calc to see how much oil I would have to move.
Sump doesn't have to hold much at all. Just a little piece of 1" pipe is plenty big enough.
I am running 1/4" feed and 3/8" return for low press and high press sides. Only about 10mL of oil to sump.
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You would have to have it so high that it develops enough head to back feed the turbo drain port. There really isnt much oil in the drain lines when the turbowerx pump is going, atleast from what i've seen.
I may run a few inches of dead vertical off the drain but planned on a few runs of horizontal line depending where pump ends up being mounted
Old 04-07-2015, 03:58 PM
MY87T/A's Avatar
Engine: 355 SBC
In my experience I feel no need to have any oil left in the turbo removed unless it was serious inlet feed. Me and a guy were talking that if all the oil drained or was pumped out after shutoff. During startup you would have a short time that the turbo would spin and have no oil to the bearings. This is minuscule amount of time but it's a thought to ponder on.
Old 04-07-2015, 04:04 PM
Mystyk_Wynds's Avatar
Car: 88 gta
GTASammy...That ones just looks Bleepin sick.
but I think everyones set ups, reguardless are sweet.
Old 04-08-2015, 08:50 AM
junkcltr's Avatar
Engine: 3xx ci tubo
All parts within an engine and external to the engine (turbo) are coated with oil before they rotate. When the engine starte to rotate so does the oil pump and applies fresh oil.
Calc the time to fill a 15 foot 1/4" diameter line. The volume is 7mL. By comparison, that is about 1/4 of the size of a standard wiskey shot.
Old 04-08-2015, 11:08 AM
MY87T/A's Avatar
Engine: 355 SBC
My inlet is 6an though as well as my return line being 6an all the way back.
Old 04-09-2015, 01:43 PM
junkcltr's Avatar
Engine: 3xx ci tubo
-6an with no restrictor?
Old 04-09-2015, 01:52 PM
MY87T/A's Avatar
Engine: 355 SBC
Yes it's restricted. Even though without it. I never had oil issues. Just needed and adaptor for a 90. So I bought a restrictive plate.
Old 08-11-2015, 10:04 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Any updates?
Old 08-11-2015, 10:25 AM
MY87T/A's Avatar
Engine: 355 SBC
Not really for the third gen. I swapped over to some vortec heads and Intake for now so should be close to 400hp crank. As for the turbo well it managed to get put back on my Silverado build and then to top it. I bought an 03 wrx to play with
Vintageracer
01-10-2020 05:33 PM
MoJoe
Fabrication
08-19-2017 07:12 PM
Eric-86sc
04-03-2016 03:52 PM
jharrison5
08-19-2015 05:53 PM
Sanjay
08-12-2015 03:41 PM
Quick Reply: Rear mount turbo. Tpi
