240$ turbonetics t4 turbo?
Old 05-23-2015, 03:19 PM
isaacim's Avatar
http://www.summitracing.com/parts/tn...rjwaAurH8P8HAQ
Found this on summit while looking for some parts... anyone use these?
Will this work well with the fuel injected v6?
I'm a little skeptical of this turbo...
Old 05-23-2015, 09:59 PM
project89's Avatar
Re: 240$ turbonetics t4 turbo?
2.8 or 3.1?
thats not an whole turbo , its a compressor housing only
give me some more info on the car itself is it bone stock , and what r ur goals for it
http://autoplicity.com/368480-turbon...rs-deptartment same part number as from summit and every other site shows it as the compressor housing only
Old 05-24-2015, 06:46 AM
isaacim's Avatar
Originally Posted by project89
2.8 or 3.1?
And here I was thinking that I found the best deal ever...
At this point I'll just go and get a 5.3 swap for less money. Thanks for the info
Old 05-24-2015, 07:48 AM
project89's Avatar
dont discard the idea yet , u can buy an ebay t3/t4 for 130 bucks shipped , or an ebay gt3582 for 200 and make around 450 hp with the v6
look in the v6 section for my v6 turbo builds and fasteddis and willieox's builds u can do a bar ebones turbo system for around 800 bucks and they are reliable
ive been using ebay turbos for like 9 years now
Old 05-24-2015, 08:51 AM
isaacim's Avatar
Aren't ebay turbos hit or miss most of the time?
450 out of a v6? Holy crap I'll look into those
Old 05-24-2015, 04:53 PM
project89's Avatar
some of the ebay turbos are hit and miss , the other turbos liek the cheap t3/t4's gt35 gt45 have been proven to be dead reliable
Old 05-24-2015, 07:44 PM
Drac0nic's Avatar
Don't forget HX35s or HY35s on the secondary market. Solid turbos that can be found at a good price.
Old 05-24-2015, 07:57 PM
project89's Avatar
also good choices , as is the he351
Old 05-24-2015, 09:30 PM
isaacim's Avatar
So after doing what i do best, researching, i have come to having a cxracing gt35 t4 turbo with the stock v6 and a custom exhaust manifold and forced induction cam
Question is, is there anyone making cams suitable for forced induction for these engines?
Old 05-24-2015, 09:31 PM
isaacim's Avatar
sorry double post
Old 05-24-2015, 11:32 PM
project89's Avatar
gt3582 witht he t3 turbine u dont want the t4 housing on a pretty sock 2.8/3.1
auto or stick?
http://deltacam.com/
^^ ask for a 260 cam its 115$ shipped with lifters with an auto trans , if u have a manual the 272 hydraulic grind will make abunch more top end power
do not get the 272 mechanical/solid lifter grind
Old 05-25-2015, 10:13 AM
isaacim's Avatar
auto or stick?
what specs for the turbo should i look for? like A/R and things like that
and im planning to swap in a manual
Old 06-12-2015, 07:08 PM
RaverRacerX's Avatar
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
on3 performance makes reliable, inexpensive turbos.
robsgta
South Central Region
10-21-2007 02:01 AM
87z28stroker
Alternative Port EFI Intakes
05-21-2006 10:45 AM
Omega
03-08-2003 01:51 AM
Quick Reply: 240$ turbonetics t4 turbo?
