Best way to evac crank case?
Old 09-28-2015, 02:07 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Hey guys. I am running a moroso crank case evac setup and I am still noticing some oil at the passenger side breather>> seems to be spitting onto the valve cover.
Ive also noticed some blue smoke(lightly) on decel.
What is everyone running to get rid of the crank case pressure?
The cylinder heads don't have many miles on them since they were freshened up so im hoping its not valve seals.
Old 09-28-2015, 07:26 PM
jimw67's Avatar
Engine: TPI 327 SBC Turbo MS2
Transmission: 200-4R CKP Stage 2
Re: Best way to evac crank case?
https://www.thirdgen.org/forums/powe...can-picts.html
See post #8. I wouldn't say it's the best system, but it seems to be working pretty well.
Old 09-28-2015, 07:47 PM
project89's Avatar
both valve covers to a good catch/seperator can and then from the can to the inlet of the turbo.
only works well if u run a filter on the turbo as it needs vacum created by the filter to work properly , its basically the same as having a vacum pump on the motor
Old 09-28-2015, 08:29 PM
At the moment I don't run a filter due to no space for it.
Old 09-28-2015, 08:31 PM
Here's what I'm dealing with
KCG
06-24-2020 04:33 AM
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
MM2Robinson
10-01-2017 09:16 AM
djmarch
05-08-2016 11:32 AM
skinny z
10-05-2015 06:23 PM
Quick Reply: Best way to evac crank case?
