Clunk in right front when braking
Old 09-26-2011, 09:33 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
I have noticed a clunking noise in the right front when I'm braking. It occurs at about 10mph and below, under light to normal braking and only once, until I brake again. I dont feel any play in the ball joints, wheel bearings are tight. I looked at the A-arm bushings and they are not cocked off or pushing out, but there is a bit of dry rot. Is it safe to assume this is my issue, or should i look at something else yet?
Old 09-26-2011, 11:01 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Clunk in right front when braking
How are the fron sway bar END LINKS???
Old 09-27-2011, 01:28 PM
drdave88's Avatar
Engine: 6.0L
Theyre only a year or so old, poly and tight.
Old 09-28-2011, 11:19 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I had that for a while... I replaced the ball joints and A-Arm bushings and it went away. I have no idea which it was, but there was no sense in tearing the front suspension apart and not replacing both.
For me if I jammed on the brakes you could hear and feel it clunk, and it wouldn't do it again for a while. I could drive forward to 20 mph, and do it again, and it wouldn't repeat. I could, however, reverse to 15 mph and jam the brakes, and it WOULD repeat. Then I could go back forward and it would do it again like clockwork.
Made me think it was the brake pads or brake related, but I couldnt find any evidence of that being the case, and then when I eventually rplaced my balljoint and A-arm bushings it did go away.
Old 09-28-2011, 09:41 PM
drdave88's Avatar
Engine: 6.0L
After looking at my brakes and suspension... my pads are over 50%, rotors have no hot spots or signs or warping. ball joints were replaced about 40k ago, but they might have been lower end brand, i dont remember. I plan to rebuild the front suspension this winter so the A arm bushings and ball joints will be replaced, but i just wanted to make sure there wasn't a crazy frame issue or anything i should be looking for.
Old 09-28-2011, 10:11 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
you know.. my friend and I searched for this for a while too.. we looked at everything.. the calipers, the pads.. the joints...
turns out... it was the brake hose, not bolted/connected to the strut, so when you brake, the line flexed and banged against the strut or wheel well, making a clunk sound...
check the brake hoses
Old 09-29-2011, 11:04 PM
coreys90iroc's Avatar
Car: 90 Iroc
Transmission: 700r4 Built by- Speed Secrets
check your battery hold down, mine did the same thing.. strapped it down tight no more clunk
Frozer!!!
01-19-2024 04:55 PM
Terrell351
06-13-2021 01:13 PM
BlackBoulder
08-11-2015 11:15 PM
MustangEater82
Brakes
08-11-2015 07:52 AM
Ginamariegault
Brakes
08-10-2015 08:33 AM
Quick Reply: Clunk in right front when braking
