Problem installing Spohn A-Arms
Car: 92 Camaro RS
Engine: LS3 6.2
Transmission: 4L70e
I recently bought spohn tubular a-arms along with a sway bar and a factory style coil spring. Here are the a-arms that I bought...
http://www.spohn.net/shop/1982-1992-...ing-Boxes.html
The a-arms mounted just fine into the car however, the coil springs are a different story. I compressed the coil springs as much as I could using an internal spring compressor. I followed the tutorial on this thread that I found about how to install new coil springs.
https://www.thirdgen.org/forums/susp...y-install.html
The problem I am having is that even with the springs fully compressed, they still won't fit into the pocket on the a-arms. Has anyone had this issue installing them before? Any advice or tips would be very much appreciated.
Car: 88 Firebird
Transmission: 5-Speed
Re: Problem installing Spohn A-Arms
Got mine installed.
I will note that I have a sway bar made by Spohn and personally it doesn't lineup with the linkage. It puts it at a great angle. Maybe due to now needing the caster and camber set correctly with an alignment.
Good Luck ~
Good Luck ~
