Installing steering shaft?
Car: '02 T/A
Transmission: 4l60e
I can't for the life of me get my steering shaft to go onto the column shaft. Am I missing something??
Car: '02 T/A
Transmission: 4l60e
Re: Installing steering shaft?
Oe. Seems to be a really tight fit. The splines are on the opposite end that goes into the steering box. This end has the pinch bolt but I can't get it to go in even with lube.
Car: '02 T/A
Transmission: 4l60e
I'm not sure what socket you're speaking of. This is the factory intermediate shaft that has no u-joint on the end that connects to the columns shaft. From the looks of it either end just goes together and the pinch bolt goes thru the hole but if only it were that simple.
Car: '02 T/A
Transmission: 4l60e
Nvm I found a pic
Check post #4, pic #3—which I think answers your question.
https://www.thirdgen.org/forums/susp...ing-shaft.html
JamesC
JamesC
Car: '02 T/A
Transmission: 4l60e
JamesC
JamesC
Car: '02 T/A
Transmission: 4l60e
I had 3 thirdgen columns so I tried the others and they would go on the shaft too easy. I ended up taking my complete column apart and swapping the parts over to a column where the shaft fit fine but now I can't get the intermediate shaft to extend at all so I can bolt it to the s10 steering box.
Car: '02 T/A
Transmission: 4l60e
Re: all the cool kids are doing this
Car: '02 T/A
Transmission: 4l60e
I see how there are splines but the factory shaft is way too small to fit around the s10 part.
Car: '02 T/A
Transmission: 4l60e
i just ordered the upgraded from from Matt Walter thru eBay. I'm getting frustrated with this car and hoping things will finally work out soon.
greasegrenade
01-13-2016 02:30 PM
