Play in joint steering shaft/gear
Car: Camaro Iroc-Z -89
Transmission: Automatic
Hello!
Is there supposed to be a play in the joint between steering column/shaft and the shaft going to the steering gear? There is on mine and I find it disturbing since there's too much play in or "sliding" in my steering wheel when turning. I'm thinking I might replace the joint for a new one.
Of course there might be more reasons causing this but I've tried to look and this was the only significant play I found. Can a bad steering gear or pump cause this behaviour? The play can be felt on both front wheels as well as in the steering wheel.
BR,
Per
BR,
Per
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: Play in joint steering shaft/gear
A great place to start for sloppy steering....
https://www.thirdgen.org/forums/engi...ing-shaft.html
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I have a question about removing the original steering shaft from the car: is this doable without removing the steering gear or steering column?
I went to garage and tried to remove it today but it seems the space is too tight for it to come out. Tried to hit the shaft upwards towards the column but it wouldn't move far enough to came loose at the gear. Any good know-how here?
Car: 92 camaro RS
Engine: LSA
I just did mine I started at the front by the box removed bolt and with a screw driver I pried the shaft back from the box. The hard part for mine was the rear column side bolt came out easy but took a lot of work to break the shaft loose from the column after I beat the shaft loose had to bend the break lines some and I pulled it out closer to the box I also have headers and it was still very tight getting it out.
Okay, thanks! So it's difficult but doable then... nothing that broke when hitting the shaft that far upwards?
The headers and heads are currently removed from the car so I guess that imporve my odds wiht getting the shaft off, if I ever manage to get it loose from the gear
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Alittle penetrating fluid at the collapsible joint will help some.
Alright! By "collapsable joint", do you mean on the middle of the shaft or the upper one close to the steering column?
There's some kind of a rubber on the middle of the shaft, is there a collapsable joint underneath it?
Thanks for helping!
Thanks for helping!
Car: 1988 Firebird Formula 350
Engine: L98 383 cubes Multipoint FI
Axle/Gears: Ford 9 inch with 3.70 gears
Here watch this video. He is switching to a different style of shaft but he shows how to take the old one out.
Thanks a lot! A very good video indeed. He purposed to cut the old shaft apart if it didn't come off, did I understand this correctly?
It seems to me that there has to be a collapsable joint on the shaft, otherwise I can't see how there's room enough for it to come off the steering gear by just knocking it backwards...
[QUOTE=perZ;5995071]Thanks a lot! A very good video indeed. He purposed to cut the old shaft apart if it didn't come off, did I understand this correctly?
Yeah u could cut the thing in half but I'd be damn sure I had a good replacement first that part can't be ordered new.
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
I took the upper joint off a 98 - 02 camaro/trans am bone yard steering shaft and installed it on a astro van clocked shaft, same as stock, bolt thru the center..
I don't know who this is, But if it's a clocked Astro Van shaft, then Yes, A bit of extra work, but fits like stock, 93 - 97 may be the same as well on the upper DD joint..
Note: You can also just notch it to make it work like the others, I just prefer the center bolt option...
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
I put the WR shaft on then marked through the bolt hole with a sharpie where to notch.
B4C5.7
Dec 12, 2015 08:35 PM
