power steering removal
Old Dec 20, 2015 | 11:11 AM
mans1's Avatar
Car: pontiac firebird trans am 1984
Engine: 5.0 v8 H.O
Transmission: auto
Axle/Gears: 700R4 auto overdrive
hi I have to remove the power steering pump and water pump will I need to remove the A/C as well or not many thanks
Old Dec 20, 2015 | 11:27 AM
Re: power steering removal
You don't "have to"; but having that thing out of the way SURE DOES make all the other easier. 2 minutes removing it and 3 minutes putting it back is worth the half-hour of it fighting you every step of the way.
Leave the lines connected of course; just take out the 4 bolts and rotate it up out of the way over toward the right front of the car. Tie it back with some coat hanger wire or something if necessary.
dragonmas
Exterior Parts Wanted
Jan 21, 2016 07:48 PM
84z28355t5WC
Dec 24, 2015 12:30 AM
apie2546
Dec 19, 2015 11:06 AM
Iblis
Dec 17, 2015 04:37 PM
