82 Camaro crossfire help
Old 02-09-2016, 06:46 PM
Socalcrossfire's Avatar
Hey everyone. I just inherited an 82 Camaro with crossfire system. The car has only around 40k miles but has been sitting for about 6 years. My question is how do I go about getting her cranked over? The fuel pump is bad from what I have been told. I do plan on eventually rebuilding the throttle body's and bushing them. I know there's going to be issues but my main concern is the fuel that's been sitting in the system. How Do I go about cleaning it? Thanks
Old 02-09-2016, 10:16 PM
snakeshooter's Avatar
Re: 82 Camaro crossfire help
Have same problem on v6 so tagged for replies
Old 02-09-2016, 10:23 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Pump the gas out, drop the tank, have a look inside and clean it out if necessary. You've got to do it to change the pump, anyway.
Old 02-09-2016, 11:09 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
with only 40k,TBIs should be in good condition-in the crossfires I have worked with,the fuel system past the tank has always been clean-seems the fuel drains back to the tank after a week or two.It is likely the injectors are stuck after sitting 6 years-pretty easy to unstick if they don't free up once exposed to fresh gas for a while.IAC valves might be stiff and could get out of sync. My original fuel pump lasted about 220,000 miles and was still working,but output pressure was low and causing poor performance.Sometimes the foam rubber coupler hose from the pump to the metal line in the tank will turn to goo and blow out.
Old 02-10-2016, 07:24 AM
82tarecaro's Avatar
Yup - that's exactly what happened to mine. If you are dropping the tank to put a fuel pump, get yourself a pump for a 1985 Corvette. It makes more pressure then a TBI pump. Later on, you can make your fuel pressure adjustable and bump it up a bit. The stock range should be 9-12 but the Crossfire likes 14 PSI
Joey Sosa
05-30-2016 09:05 PM
SUPER CHEVY66
22
03-06-2016 01:29 PM
someone972
02-25-2016 03:11 AM
85@IRocZ
02-01-2016 08:09 AM
Firechicken86
01-17-2016 10:59 AM
Quick Reply: 82 Camaro crossfire help
