thanks...
Old 12-19-2000, 12:35 AM
rezinn's Avatar
thanks...
I have tried both of those... was a great reply though
Today I installed the new distributor, started it up and it worked fine. I had some error codes in from before, so I turned off the ignition, stuck in my new GM code scanner, and put it back on--my fans turned on (is that bad?) and I recorded a 34 error, which is some MAF code. Now my car wont start, it wont even crank, Im thinking this scanner shorted out something, I don't think my fans were supposed to come on when I hooked it up, none of my friends did either. Any ideas?
Old 12-19-2000, 12:36 AM
rezinn's Avatar
doh, that was meant as a reply to Vader, sorry :P
Old 12-19-2000, 12:38 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
When you check codes the fan comes on all the time.
Old 12-19-2000, 12:41 AM
rezinn's Avatar
Ok, but still..could the scanner mess anything up? I will check fuses and wires tomorrow after checking this post. Thanks again.
Old 12-19-2000, 10:43 PM
Vader's Avatar
Rezinn,
The scanner shouldn't have caused any damage, and the fan(s) normally run when in diagnostic mode. As long as you didn't try to crank the engine when the scanner was installed, there should be no damage to the ECM.
If it won't even crank, there is a problem with the safety interlocks, VATS, fuse/fusible links, or starter. Get it cranking first, then take it from there.
If you think you might have damages or "scrambled" the ECM by cranking while the scanner was installed, try disconnecting the battery for about ten minutes (long enough to clean the cables and terminals), then reconnect it. This should clear all RAM and error codes.
Waiting for results...
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old 12-20-2000, 03:41 PM
rezinn's Avatar
How do I test the starter/wiring/solenoid while they are in the car?
Going outside now, no bad fuses as of yesterday, my battery has been disconnected for a whole day.
Old 12-21-2000, 12:06 AM
rezinn's Avatar
The solenoid is good, the fuses are good, dont know if the starter is.. any way to check that with it in the car?
1HotZ28&SS
Brakes
09-01-2015 04:33 AM
Greg Kuhlmann
12-18-2001 08:03 PM
Nitroburn
12-04-2001 11:09 AM
Nitroburn
11-30-2001 03:36 PM
AudioDEO
11-12-2001 08:50 PM
Quick Reply: thanks...
