what the he!! is this???
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
i have a 350 carb camaro. and when i start it up in the moring it starts off at 1000rpms to warm up then it goes to 1500rpms-2000rpms. then i can usually hit the gas or put it in gear and it will drop to like a 1000rpms idle put now it is staying on 1500-2000rpms when im driving around and it wouldn't go down. how do i make it go down to idle? is something getting stuck? thanx for the help
86 Z28:
350 vette
aluminum heads
T-5
235/60R15 BFgoodriches
dual 3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt Sony xplod amp
Sony xplod deck
K&N air filter
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
does it have an electric choke on it? if so, check it. not htat it affects idle terribly, but just check and make sure your timing didnt get wacked up somehow. I had the same problem on my carbed 383, it was such a bltch to put in gear cuse it would jolt the car so badly. anyhow, check those, im sure its the idle control
- 83 Z28--ttops, 200k miles--very ragged out. sold, thank goodness
- 74 Z28--slightly modded 383, TH400 tranny, not too quick but fun to drive
Mike,
Check the power to the chocke heater. You should also check the auxilliary oil pressure switch, since your engine MAY have the switch in the choke heater circuit (I'm not sure what year that started/ended).
You should also check/clean/lube the high idle cam to make sure it can move freely.
Later,
Vader
"Fear is how I fall, Confusing what is real..."
Adobe Acrobat Reader
Later,
Vader
Car: 92 Z28 Z03
where is the choke heater and the auxulliary oil switch and how would i go about checking the power?
thanx for the help!!
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
1 Post
Car: 99 Formula
Axle/Gears: 342
This was happening to me a couple of weeks ago, turned out that my throttle return spring had a kink and wouldn't close all the way, just something to check.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Rebuilt 700R4, with manual valve body
Soon to be installed B&M Megashifter
and Exhaust Cut-Out
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
2:73 GEARS
and Exhaust Cut-Out
Car: 92 Z28 Z03
someone told me this might be the problem to. how did u fix the kink? did u get a new spring? thanx
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
1 Post
Car: 99 Formula
Axle/Gears: 342
Actually now that I think about it what happened was at the end of the spring where it connect to the throttle it had just positioned itself wrong and was stuck there holding the throttle open at idle. All I had to do was take of the spring and put it back on, yours may have a different problem w/the spring if that is what's causing your problem.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
2:73 GEARS
and Exhaust Cut-Out
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
2:73 GEARS
and Exhaust Cut-Out
