what does it take?
Old 07-17-2005, 02:54 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
what does it take?
what does it take to reach 500hp at the wheels? my engine combination is going to be a 355 with forged speed pro pistons, forged esp eagle h beam rods, forged 4340 eagle esp crank. as well other standard stuff like arp bolts, milidon oil pump/pan. i plan to run the gm fast burn alluminum heads with the edelbrock pro flow efi system. this seems like a pretty descent combination. im more than likely going to have a custom cam ground by comp. friends have told me ill be in the 450hp range at the crank. and i want n/a 500hp at wheels. any suggestions? keep streetablity in mind.
Old 07-17-2005, 04:35 PM
sixpackmtrspts's Avatar
not possible in my opinion with only 355 inches, now a 383 or a 400 might get you there and still be streetable.
Old 07-17-2005, 04:55 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
stroke the 355, if you are buying pistons bore it over as well. It will get you there, why 500hp @ the wheels?
Old 07-17-2005, 06:34 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Supercharger!
Old 07-17-2005, 08:54 PM
Cruz'N Bruz'R's Avatar
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
If your forging the whole bottom end, then nitrous will not be a problem. That would be your cheapest and easiest solution.
Old 07-17-2005, 11:02 PM
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
why 500hp? because its right in the middle. my dream is to build a car that has 1000hp but we all know thats really expensive and im only 19 so not really possible at this point. unless i owned a supra. if i used nitrous how would it work if i ran 10.6:1 compression isnt that a little high? so if stroked it to a 383 plus the .30 over i would have a 388? i heard they dont rev to high compared to a 350/355 because of the stroke. do you think with my setup that i could react 500hp with only 33 more cubic inches?
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Old 07-18-2005, 12:07 AM
3rd gen V8's Avatar
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
common guys you say that you cant with only 355 ci my buddys mustang cobra has a 4.6L with 500+ to the wheels. and oh by the way, The old saying is, Its not cubic inches but cubic $$
Old 07-18-2005, 12:12 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yeah but he has a power adder, nitrous, supercharger or turbo.
Old 07-18-2005, 12:48 AM
3rd gen V8's Avatar
Oh i gess i forgot to mention he has a whipple charger on it?
Old 07-18-2005, 06:55 AM
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
nitrous likes compression
boost does not like compression.
