100 psi on new heads
Old 08-03-2006, 09:32 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I put some 76cc heads on my 305 and its only got 100 psi. Roughly 7.5:1 compression. Im putting a centrifugal supercharger on it and im wondering if the compression will be ok or if the super crap stock heads would be better? The new heads are rhs torkers. 170cc stock replacement but much better flowing than the swirl ports.
Old 08-03-2006, 02:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You can run ALOT of boost with 7.5:1 compression... most guys who build a motor specifically to use a blower, use a CR around that, so you should be fine. Just get a cam to match and you should be good to go if the bottom end can handle it.
355sbcTPI
08-19-2015 04:38 PM
86White_T/A305
08-17-2015 12:16 AM
mdtoren
08-16-2015 05:45 PM
BBSDesigns
08-11-2015 07:39 PM
Quick Reply: 100 psi on new heads
