power steering pump/ Help!!!!!
Old 05-14-2009, 09:00 PM
droptop89's Avatar
Car: 89 rs convertible
Engine: stock 305 ci
Axle/Gears: 327 open or something
Help, Im putting in a new pump, Do i have to remove that hole bracket or can i remove the pulley and unbolt it, What holds the pulley on its pretty dirty and full of sh_t is it a allen head or star ? any help out there. Thanks vaughn P.S great site
Old 05-14-2009, 10:45 PM
IROCthings's Avatar
Car: 85 335IROC Camaro
Engine: 335 tune port
Transmission: 700r4 Stage 2
Axle/Gears: 3:73
Re: power steering pump/ Help!!!!!
well the piece that holds on the power steering pulley is the power steering pump the pulley is what helps pump the fluid to help the smoothness of the steering on power steering. so you have to replace the whole piece the power steering pump and all. unless the pulley is stripped and that's what your repacing. but i don't even know if thats the way it works normally you replace the whole unit.
on a side note me and my friend on both our cars cut our power steering off at the lines and just looped them to keep fluid in and basically turned it into a rack and pinion. but yea hope that answered your question.
Old 05-14-2009, 11:57 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Unless your friend has some kinda magic wand disconnecting the p/s from a gearbox doesn't turn it into anything resembling a rack and pinion.
Old 05-15-2009, 12:02 AM
Car: 86 T/A
Engine: 5.0 TPI
The pulley is pressed on and requires a special puller to remove it.
Old 05-15-2009, 04:05 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Yeah. It's a press fit.
You can replace the pump and pulley separately.
You can also do it with the bracket still mounted to the engine. You may have to remove your fans though if you can't get enough room for the puller.
Old 05-15-2009, 07:25 AM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
The puller needed to remove the power steering pump pulley can be 'borrowed' from AZ or one of the other chains. Do not try to use a claw type gear puller. It will damage the pulley.
Your local store may even do it for you if you bring in the parts and ask nice.
Our gearbox type is referred to as Recirculating Ball which is mechanically different from Rack and Pinion.
Old 05-15-2009, 08:58 AM
PV9685's Avatar
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
That's a great reply! LOL! hmm, maybe they like it stiffer feeling, lol. Like - Reeeeeallllllly stiff!
Old 12-11-2009, 10:37 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Hi, so in order to remove the p/s pump, i have to remove the pulley while the p/x pump is still installed?. do i need flare nut wrenches for the hoses?
Squeaky8791
02-05-2020 08:29 PM
Vintageracer
01-10-2020 05:33 PM
Chuck84TA
07-15-2016 09:05 PM
evilstuie
04-14-2016 08:52 PM
deracer
04-11-2016 12:04 AM
Quick Reply: power steering pump/ Help!!!!!
