Nodular iron crank and 400hp?
Old 10-09-2009, 04:22 AM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
Well my L98 decided it didnt wanna run anymore and needs a rebuild.
So to keep it simple im just gonna order a new shortblock. I dont think I need a forged crank and rods but I could be wrong. I plan on doing a decent set of heads and cam. Im shooting for around 350hp/450ft lbs with the stock tpi manifold. But I was really wanting to add a 100 shot for the track or the occasional new vette who pulls up next to me.
Just wanting opinons if I need a forged crank.
Old 10-09-2009, 08:18 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Nodular iron crank and 400hp?
It will hold 400hp
Old 10-09-2009, 10:40 AM
On Probation
Atilla the Fun's Avatar
Engine: several
Transmission: none
Axle/Gears: none
You should be fine, so long as you keep it from having detonation.
Old 10-09-2009, 02:05 PM
wannafbody's Avatar
Car: 88 GTA
hopefully I can learn to tune it and keep that from happening, Thanks, Im guessing I wouldn't need forged rods either then..?
Old 10-09-2009, 02:14 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I wouldnt worry about with only 100 shot and only spraying now and then. Double the hit and heavy track/street use and I would say yes go forged.
Old 10-09-2009, 02:53 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
stock rods are forged. The main thing that kills them is rpm. The heavier the piston, the less they'll tolerate. just get some pre-1980 rods, and have them fitted with ARP bolts then resized. That'll serve most any 350 to 6500 rpm over and over again.
Old 10-10-2009, 05:12 AM
wannafbody's Avatar
Car: 88 GTA
thanks everyone
Falcon50
08-22-2020 03:26 PM
RS Reaper
10-17-2018 07:52 PM
skinny z
10-05-2015 06:23 PM
Badass355ciz28
09-28-2015 08:31 PM
mfp189
09-27-2015 09:25 AM
Quick Reply: Nodular iron crank and 400hp?
