is there an actual benefit to roller tip rockers?
Old 06-25-2010, 12:23 AM
shanep1991's Avatar
i was just wondering if theres an actual benefit to them, im doing a cam/lifter swap and am also getting new pushrods, would it be worth the 84.99 for the roller tips or are my stock ones good? its just on a 305 with flat tops and 416 heads, headers, diff intake and carb also, just need to know if its really worth it
Old 06-25-2010, 12:37 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: is there an actual benefit to roller tip rockers?
Well it depends on a couple things
First, would your heads handle the lift of the new cam plus a set of 1.6 rockers? If so, then buy the 1.6 rockers and get them in roller style. One of those "might as well" type things
If you're just replacing 1.5s with 1.5s, then no, you wont notice the difference. You'd only notice the difference if it was a monster engine and you were trying to force every last bit of power out. Considering it's a 305 with 416 heads, I'd say you're not building a 'monster' motor.
Old 06-25-2010, 12:49 AM
shanep1991's Avatar
if i do decide to replace them im going to 1.6
Old 06-25-2010, 06:19 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Then you will need to replace the valve covers too.
Old 06-25-2010, 06:54 AM
stealthroc89's Avatar
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
Replace the valve covers?
Old 06-25-2010, 06:57 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Some roller tip rockers and all full roller rockers require a taller valve cover. It just depends on how tall the new rockers are.
Old 06-25-2010, 11:01 AM
shanep1991's Avatar
ive already got tall valve covers, but thanks guys i think ill go buy some then
Old 06-26-2010, 02:56 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Speaking in absolute terms like "all" can be misleading. Not all full rollers require taller covers. i swapped to ARP 1.900" tall screw in studs, checked and found 7.200" pushrods were the right length and the stock covers dropped right on. So some "yes"; "all" no.
My son's 96 LT1 Vette didn't need different/taller covers when I installed Scorpion 1.7, 7/16" full bodied roller rockers last year.
Jake
Hotrodboba400
12-10-2019 07:07 PM
TX-SleeperC5
02-24-2016 01:34 PM
Jorlain
10-08-2015 01:57 AM
New2Chevy
09-28-2015 12:35 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: is there an actual benefit to roller tip rockers?
